Author Topic: PCL: Blink module  (Read 91623 times)
Re: PCL: Blink module
« Reply #105 on: 2013 January 29 17:50:38 »
Hi Nikolay,
I can't isntall Blink v1.1.3 for PI 1.8.x: Bin Linux64 in PI 1.8 RC3.
Is there something wrong between my monitor and the chair or the module needs  something else for RC3?
Saludos, Alejandro.
Offline NKV
« Reply #106 on: 2013 January 30 02:11:51 »
Dear Alejandro,
Please use standard version of Blink module which included inside the distribution package.
Or you have any problem with standard version?
Best regards,
Nikolay.
« Reply #107 on: 2013 January 30 02:26:25 »
Hi Nikolay, standard version works perfect, but it don not have the "create video" option.
Saludos, Alejandro.
« Reply #108 on: 2013 January 30 16:10:12 »
also, nikolay, you may have seen the "automatic histogram xform" thread. i *swear* i used blink to apply a HT to each image and save them to disk with the HT applied, but i can't duplicate the behavior. the Animation script works when i try to do this. in blink i've both tried to copy the files and to save a crop from blink and the HT is not applied to the saved file.
i am not sure what version of blink i am running. as far as i can tell i have never compiled your source code, so it must be the default version that comes with 1.7.
Offline NKV
« Reply #109 on: 2013 January 30 20:41:09 »
PI 1.8. don't allow run external processes, or maybe i not understand something in c++.
My compiler not allow to use fork() command in PCL namespace.
So, i cant build latest Blink version for latest PI right now. Give me Give me some time.
Offline NKV
« Reply #110 on: 2013 January 30 20:44:39 »
yes, you are right. Latest Blink version much better, more features for HT processing.
I will adapt the module for PI 1.8 RC3 soon.
« Reply #111 on: 2013 January 30 23:52:43 »
See http://www.pixinsight.com/developer/pcl/doc/html/classpcl_1_1ExternalProcess.html
« Reply #112 on: 2013 January 31 00:04:16 »
I was going to write the same link; Georg he has been faster :)
Nikolay, please let me know if you need help to adapt the latest version of Blink. Movie generation is definitely a must-have for PI 1.8 on all platforms. By the way, what applications are you using to generate the movies? Can I suggest ffmpeg? It is cross-platform and distributed under LGPL 2.1, so we can distribute it with PixInsight on FreeBSD, Linux, Mac OS X and Windows.
Offline NKV
« Reply #113 on: 2013 January 31 00:31:08 »
Juan, i use avconv because Ubuntu says about ffmpeg:
*** THIS PROGRAM IS DEPRECATED ***
This program is only provided for compatibility and will be removed in a future release. Please use avconv instead.
Anyway no matter which converter is better. User can choose it via menu.
Offline NKV
« Reply #115 on: 2013 February 01 06:17:53 »
Hi Nikolay, thank you.
The version I can download for RC3 say "Blink-pxm.so.Linux64.PI1.8RC3.v1.1.3.1.gz", not 1.1.4.1. Is the correct one?
Saludos.
Alejandro.
Offline NKV
« Reply #116 on: 2013 February 03 22:08:01 »
It's just mistake in file name of the gz file. Inside there are version 1.1.4.1. fixed.
Any way you can see which actually version is installed in ProcessExplores>ProbertyBrowser> description.
it's standard access restriction to system folders. Try to do it inside your home folders.
Offline NKV
« Reply #117 on: 2013 February 05 00:34:33 »
v1.1.4.1 for PI1.8 RC3
Linux64
Win64
Offline NKV
« Reply #118 on: 2013 December 23 08:46:02 »
Can anyone help me with ExternalProcess problem ?
Offline NKV
« Reply #119 on: 2014 January 28 03:29:43 »
v1.2.1.0001 - Make Video adapted for Linux and Windows OS.
You can use the Blink module for video coding from images.
Instruction:
1)Define by green rectangle region of interest.
2)Link Blink module to command line coder and set parameters of coding.
3)Select output folder.
4)Push Run.
