Author Topic: vdB 152  (Read 3561 times)
Offline christophwoehrle
vdB 152
« on: 2011 November 10 01:16:42 »
I am more a reading person than a posting guy, but now I would like to share a photo with You
My first photo completely developed with PI. Before I always did some fine tuning in PS.
But after having studied lots of tutorials I am quite satisfied with the result.
TLAPO Triplet 80/480 with TSFLat2 and Atik 383L+
Guiding with Lacerta Mgen and Mgen2Maxim for Dithering
Taken at the ITT in Carinthia 2011
L:R:G:B in min (200:100:100:100)
full resolution ( attention it is really the full resolution )
http://astro.christophwoehrle.com/vdb152/vdb152.html
I hope You like it to  ::)
Chris
www.astro.christophwoehrle.com
Offline Lex
  • We do it at night...
Re: vdB 152
« Reply #1 on: 2011 November 10 12:12:02 »
Chris,
You are right, I absolutely like your awesome picture!
You have pratically the same setup as mine  ::)
What mount do you use?
Clear Skies!!
Lex
Re: vdB 152
« Reply #2 on: 2011 November 14 04:15:13 »
Hi Lex,
thanks for the compliment.
Yes, it is nearly the same equipment.
I am using a CGEM :-)
Chris
Offline Lex
Re: vdB 152
« Reply #3 on: 2011 November 14 07:25:53 »
So,
this is really pratically the same setup as mine  ;D
Have you done something with your mount, aka Hypertuning; PEMPRO or soemthing like that?
I am not really satisfied with its accuracy and look for something to do against this..
Clear Skies!!
Lex
Re: vdB 152
« Reply #4 on: 2011 November 16 03:51:50 »
Hello Lex,
well I took the CGEM out of the box and all I did since then was a firmware update. Never changed anything.
But the main thing that helps me get exposure times if 60min singleshot and pinpoint is the auto guider Mgen.
Did You activate something like a PEC or Backlash compensation?
Chris
Offline Lex
Re: vdB 152
« Reply #5 on: 2011 November 16 07:50:40 »
I just did PEC training with the PEM  Pro software..
I am able to do exposures of 1200 sec, sometimes it works well and other times not at all.
600 sec exposures are commonly okay with good shaped stars..
I did not touch backlash compensation because i often read that it very hard to configure these settings.
Clear Skies!!
Lex
Re: vdB 152
« Reply #6 on: 2011 November 18 06:01:25 »
Hi Lex,
I recommend to keep all features like PEC or backlash switched off.
Most autoguiders will compensate much better without all that stuff.
Chris
Offline Lex
Re: vdB 152
« Reply #7 on: 2011 November 18 07:39:58 »
Christoph,
In the beginning I though the smae, but after several months of using my setup i tried to do some PEC trg and my tracking graph was flatter than ever...
I know that most guiders should be used with no PEC activated, but not mine i guess  >:D
Clear Skies!!
Lex
