Author Topic: 2005 YU55 movie  (Read 6638 times)
2005 YU55 movie
« on: 2011 November 09 20:15:18 »
this is 35 x 60s exposures with a canon 50d and 200mm lens @ f/4.
pixinsight: calibration, registration, crop, lum extraction, histogram stretches
astrometry.net: overlay grid (unfortunately it does not label the grid :( )
netpbm: fix fits origin problem
mencoder: make mpeg4 avi movie at 4fps
the movie is 1080p so be sure to enlarge it...
http://www.youtube.com/watch?v=X1UXZXA1S6c
Offline Giorgio
Re: 2005 YU55 movie
« Reply #1 on: 2011 November 09 23:52:47 »
Hello,
this is a difficult object, also a very fast stone! Good work! pfile
Giorgio.
Re: 2005 YU55 movie
« Reply #2 on: 2011 November 10 10:48:46 »
thanks, giorgio!
Offline Lex
  • We do it at night...
Re: 2005 YU55 movie
« Reply #3 on: 2011 November 10 12:18:32 »
Pfile,
Nicely done, I like this kind of films; better than Spielberg  O0
Clear Skies!!
Lex
Offline christophwoehrle
Re: 2005 YU55 movie
« Reply #4 on: 2011 November 10 13:10:19 »
Looks nice.
Fast little giant
Chris
Re: 2005 YU55 movie
« Reply #5 on: 2011 November 10 15:31:40 »
thanks lex and chris.
does anyone know if there is an automagic way to normalize the background brightness in each frame? i tried linearfit but that seemed to mess up the images. i cant remember now if i did LF before or after stretching them though.
Offline Lex
Re: 2005 YU55 movie
« Reply #6 on: 2011 November 11 00:32:07 »
Pfile,
the best way to deal with this kind of task would normally be the LinFit function.
I think this function can be applied to Lin or Non-Lin images, but to achieve a homgenic result it should always be applied to either the L ore the NL images. IMHO
Btw: I think the "fuzzy" aspect of the background area gives this little shorty a nice "scientific" touch  O0
Clear Skies!!
Lex
Re: 2005 YU55 movie
« Reply #7 on: 2011 November 11 08:47:30 »
well, that's what i thought and i have used the linear fit function before for this purpose. i'm not sure why it did not work this time.
it's all kind of a pain because ImageContainer works for some processes and not for others. working on 35 images is a big pain if the ops have to be done individually.
Offline oldwexi
    • Astronomy Pages G.W.
Re: 2005 YU55 movie
« Reply #8 on: 2011 November 11 10:53:26 »
Hi Pfile!
A very difficult task, and you mananged to get an excellent viedeo!
To your questions.
The PixInsight Animation script does an Autohistogram to all images with one mouseclick.
When i make videos i let the cropped and registered images run with PI-animation using autohistogram.
In the background  i capture the video from the PC-Screen with the software "MAGIX".
Another solution for getting the the same background brightness for all images is PIxelMath.
If i want for example the background at 0.18
The Pixelmath expression could be:
(Symbols define):
B, Diffa, Diffb
PixelMath RGB/K Expression:
B = 0.18;
Diffa = median($T) - B;
Diffb = B - median($T);
iif(median($T) > B, ($T) - Diffa, ($T) + Diffb)
PixelMath works nicely with Image container.
For sure there are other solutions but this one seems to work for me.
Aloha
Gerald
Re: 2005 YU55 movie
« Reply #9 on: 2011 November 11 14:48:36 »
That's a very interesting information Gerald, thank you very much for sharing.
Regards, Alejandro.
Re: 2005 YU55 movie
« Reply #10 on: 2011 November 11 16:30:53 »
thanks gerald. i did use the animation script while i was capturing the pictures to see if i had actually gotten anything. however, i wanted to annotate the pictures with an RA grid and also the date and time.
the problem is, even with autohistogram (which i did to all the images by hand) there were a handful that were somehow quite different and the autohistogram yielded a much dimmer picture. i'm not sure why that happened, but there were thin clouds so it could be that some of the frames are just brighter than others.
what i should do is try your pixelmath, then use imagemagick to annotate the frames and make a new movie that's got better annotations and is also not juddery. it seems that youtube had a hard time with the 4fps movie when converting to 30fps. not too surprised by that, should have tried 5fps.
Re: 2005 YU55 movie
« Reply #11 on: 2011 November 12 13:17:18 »
the pixelmath worked great, thanks for the help.
Offline Lex
Re: 2005 YU55 movie
« Reply #12 on: 2011 November 13 01:16:51 »
Wow, i really admire people having the know how with PixelMath!
I only know the real minimal basics  :-\
Btw.: Is there a docu for PM on the forum?
Clear Skies!!
Lex
Offline zvrastil
    • Astrophotography
Re: 2005 YU55 movie
« Reply #13 on: 2011 November 13 04:17:02 »
There's even full reference document. For some reason, it's in the Tutorial section of the PixInsight website: http://pixinsight.com/tutorials/PixelMath/en.html
Zbynek
Offline Lex
Re: 2005 YU55 movie
« Reply #14 on: 2011 November 13 06:15:50 »
Zbynek,
Thanks for this info, i'll check that out out and studdy some Pixelmath, not an easy lesson I guess  >:D
Clear Skies!!
Lex
