Author Topic: Electroluminsecent Panel for Flat Frames  (Read 6276 times)
Offline Luigi
« on: 2011 November 02 12:52:34 »
Anyone using an electroluminescent panel for flats?
How did you decide the correct size? Currently I have a 152mm refractor, will an 'A4' size panel be sufficiently large? I'm thinking I hang it on one of my observatory walls and point the scope there.
Luigi Marchesi
Re: Electroluminsecent Panel for Flat Frames
« Reply #1 on: 2011 November 02 13:02:47 »
yes, recently i started using one. i think the one i bought is A4-sized. i just point up, lay it on top of the objective of my C8 or of my 200mm lens and put a paperback book on top.
i'm not sure how far away you can put such a small panel and still have it work, i have never experimented with it.
Offline Luigi
« Reply #2 on: 2011 November 02 14:02:17 »
Thanks. I suppose I could hang the panel just in front of the dewshield and I'll be OK.
Is a laptop screen a good alternative until I get an ELP?
Luigi Marchesi
« Reply #3 on: 2011 November 02 14:04:33 »
yeah, you could do that. i have heard of people using their laptop screens for this purpose. i've never tried it though.
Offline Luigi
« Reply #4 on: 2011 November 02 18:15:58 »
BTW where did you get yours?
Luigi Marchesi
Offline chris.bailey
« Reply #5 on: 2011 November 03 05:17:22 »
I use one of the Gard Newmann ones that are circular. I found the cheaper ones, whilst ok for LRGB, didnt give decent results with narrowband. Since using it I have got flats that actually work!
« Reply #6 on: 2011 November 03 06:24:00 »
You probably mean Gerd Neumann http://www.gerdneumann.net/v2/english/eng_aurora_flatfield_panels.html. Yes, these are good!
« Reply #7 on: 2011 November 05 11:09:39 »
Darnit, looks like the one I got is a fake :-)
Offline Lex
  • We do it at night...
« Reply #8 on: 2011 November 07 07:37:29 »
The ELP's of Gerd Neumann are the best considering the luminance uniformity.
I collect my Flats scope/mount in park position and the ELP fixed to the scope with little magnets. ( not ideal for automated setups )
If you have an automated setup it is possible to use it just like a dome flat, just be sure that there is no direct light source causing reflections on the ELP.
I tried the use of the LapTop screen also with a very non-uniform result ( unless you have a real good LED screen i would not opt for this )
Clear Skies!!
Lex
« Reply #9 on: 2011 November 07 10:11:36 »
well, i just got some el-cheapo one from fleabay (direct from china). you know, because we jam econo over here. i should measure the spectrum and see if it's any good.
