Author Topic: Excess Noise in Calibration  (Read 3620 times)
Offline andyschlei
    • http://www.obsballona.org
« on: 2011 October 30 18:45:46 »
In working on a new image I have come across a problem that I haven't had before.  I am ending up with dark black speckles in the image.  I have done a comparative calibration with CCDStack and I don't have the same issue.  I feel I must be doing something wrong.
The problem is only occurring in my color data
Here is my workflow.
  • Create master bias from 42 frames
  • Create master dark from 42 frames (-20C, 300 seconds)
  • Create master flat, calibrating using above mentioned darks and flats, these three steps all in accordance with the settings recommended in the dark/flat tutorial
  • Calibrate lights using the above master files
  • Align all luminance, combine (no problem with end result there), downsample the aligned luminance using integer resample to be binned 2x2, align RGB with the downsampled luminance.  I resample the RGB using nearest neighbor so every bad pixel ends up on one destination pixel rather than being spread out.
  • Combine blue (for this example) using the following settings.  Note that the RGB frames in this case are 200 seconds each and at -18c.  I've had no trouble with the difference in time and temperature in the past.
    • Combination: average
    • Normalization: additive
    • Weights: Noise Evaluation
    • Pixel rejection: Averaged Sigma Clipping (I have 6 frames in this case)
    • Normalization:  Scale+Zero offset
    • sigma low: 1.7, sigma high: 1.7 (I'm expecting it to have outliers)
In my integrated image, I get dark pixels that are less than 50% of the value of those around them.  I tried this same workflow in CCDStack (which uses dark adaptation method they call RMS) and did not have the dark pixels.  Sample images are attached.
The underlying images are all dithered.
I feel I must be doing something wrong since I have not had this trouble with similar data sets.
Thanks in advance,
--Andy
Observatorio de la Ballona
CDK 12.5, NP-101, C-11
AP-1200, AP-900
ST-10 XME, CFW-8, Astrodon v2 filters
Pyxis Rotator, TCF Focuser
Re: Excess Noise in Calibration
« Reply #1 on: 2011 October 30 22:29:23 »
i had a similar problem a while back... got this reply from vicent:
http://pixinsight.com/forum/index.php?topic=2788.msg18986#msg18986
unfortunately, i don't think the new IC process has been released.
Offline andyschlei
« Reply #2 on: 2011 November 01 16:18:23 »
I have not had this problem with similar data sets.  Hence my belief that I must have a step or setting wrong.
AP-1200, AP-900
Offline andyschlei
« Reply #3 on: 2011 November 20 10:55:37 »
Interesting update.
As an experiment, I calibrated the data in CCDStack and aligned and combined in PI.
The problem persists, so the difference comes from differences in data rejection and combination.  I am using identical sigma settings in both programs.
Go figure.
--Andy
One other comment:  The SNR on the images is very low, they are short (200 seconds) and the object (NGC 7814) is quite dim.  That may be why I am having problems with this particular set of data.
« Last Edit: 2011 November 20 14:18:24 by andyschlei »
AP-1200, AP-900
astropixel
  • Guest
« Reply #4 on: 2011 November 21 15:23:58 »
Andy. I'm not sure if this is helpful, or which tutorial you followed.
http://pixinsight.com/tutorials/master-frames/en.html
http://pixinsight.com/forum/index.php?topic=2570.msg19019#msg19019
Each treats flat frames differently. The original tutorial shows the Calibrate check box selected, applicable to lengthy flat exposures requiring dark calibration. The later version does not select calibrate because the flats are of a short duration 1/10second - therefore no appreciable dark signal. Both are correct, as you know.
SNR doesn't appear low enough to be a problem. I've seen lower and managed to calibrate etc.
