Author Topic: NGC 7331 + IFN  (Read 4740 times)
Offline ManuelJ
    • ManuelJ Photography
NGC 7331 + IFN
« on: 2011 October 27 03:15:34 »
This is my attempt at showing the IFN that it's surrounding NGC 7331. I think that maybe there is some kind of tidal added in the background.
I used this time excalibrator for color calibration and it just works wonderfully.
http://www.manuelj.com/Astronomy/Galaxy/NGC-7331
Manuel.
Offline Lex
  • We do it at night...
Re: NGC 7331 + IFN
« Reply #1 on: 2011 October 27 03:37:32 »
Manuel,
There is nothing else to say to you image than WWWWWWOOOOOOOOOWWWWWWW!!!!  :surprised:
Really absolutely nice!!!
Respect
Clear Skies!!
Lex
Re: NGC 7331 + IFN
« Reply #2 on: 2011 October 27 04:05:04 »
Hi Manuel,
Very nice image. Did you try ColorCalibration using 7331 as the white reference?
Offline ManuelJ
Re: NGC 7331 + IFN
« Reply #3 on: 2011 October 27 04:32:42 »
Hi Manuel,
Of course, but sadly it didn't work as expected. It appeared quite purple.
Using color calibration it's not very... straightforward for me.
Manuel.
Re: NGC 7331 + IFN
« Reply #4 on: 2011 October 27 06:14:43 »
Hmm. You applied BN/CC to the linear image, didn't you? If yes, then I'd appreciate if you can upload the linear RGB image, if possible, just after combining the calibrated raw frames. If CC didn't work for your linear images then I definitely want to debug it. If not, then we know why it didn't work: no (correct, sound) color calibration procedure can be implemented with nonlinear data.
Offline Ginge
Re: NGC 7331 + IFN
« Reply #5 on: 2011 October 27 11:30:20 »
A magnificent image Manuel. You can even glimpse a tidal stream as you mention on the left side.
Could you share more of the processing steps? Dynamic PSF? deconvolution?
Very well done!
Ginge
Offline Daniel_Guetl
  • Amateur Astrophotographer and CCD Enthusiast
    • Astrostyria
Re: NGC 7331 + IFN
« Reply #6 on: 2011 October 27 11:36:21 »
Hi Manuel,
impressive equipment and an impressive image :) Looks like you have everything under control  :)
regards,
Daniel
Offline Lex
Re: NGC 7331 + IFN
« Reply #7 on: 2011 October 27 22:00:02 »
Manuel,
Just one more question, how did you do it to buy all this equipment?
I dream about stuff like that but wonder how I could buy it ;D
Best
Clear Skies!!
Lex
Offline Yuriy Toropin
Re: NGC 7331 + IFN
« Reply #8 on: 2011 October 28 02:12:58 »
Manuel,
very deep and impressive!
Is there any special reason why you limit L exposures by 10 minutes only?
Offline ManuelJ
Re: NGC 7331 + IFN
« Reply #9 on: 2011 October 28 07:23:48 »
Juan Conejero: Yes, I used your tutorials step by step with linear images. You can get the fit files here: http://www.megaupload.com/?d=QIBN0JDM
Ginge: My processing steps (more or less)
- Deconvolution to L with DPSF, applied the deconvolution only to the brigther zones.
- RGB combination with the parameters defined by excalibrator.
- SCNR to the green
- Histogram transformation to both RGB and L images, linear fit the L's
- Combination of the final LRGB and histogram transformation
- HDRWT to the brighter part of the image minus the stars, to avoid the black centers
- LocalHistogramEqualization to the weak parts, increasing contrast
- Morphological transform with a star mask and then a ATWT to get smooth stars back
- Weak ATWT to brighter parts (not stars!) to recover the contrast lost
- ACNR to the crominance
- Greycstoration to the luminance with various masks
Lex: 5 years of savings, and 5 years of credit :) . I'm not rich, but a dream is a dream.
Yuriy Toropin: to avoid star bloating, and because I don't have any special reason to go with larger subs. In narrowband I go with 30 min subs always, but there it's quite clear that I have to expose more time
Thanks all!
Offline Lex
Re: NGC 7331 + IFN
« Reply #10 on: 2011 October 29 07:40:48 »
Hehe, i started saving also  >:D
So maybe in 10 years i could show pictures like yours ;D
Again; your results are impressive!
Congrats
Clear Skies!!
Lex
