Author Topic: GreyCStoration: Differences at 16 vs. 32 bit  (Read 7594 times)
Offline andyschlei
    • http://www.obsballona.org
« on: 2007 October 09 21:53:36 »
I am working (first pass really) with some image data and got to noise reduction.
There was a fair amount of noise but I got a good result with 3 iterations of GreyCStoration noise reduction.  When I went to save before processing the whole image (I was testing on a preview) I noticed that the image was at 16 bit integer -- I had forgotten to move to 32 bit floating point earlier in the process.
I had my processing history, so I started over.  When I got to noise reduction, the results were entirely different.  The same noise reduction that worked at 16 bit integer totally blurred the image when working in 32 bit floating point.
Why would otherwise identical images have different noise reduction results due to different bit depths?  Does the lack of precision prevent the excess blurring that occurs in the more precise data space?
I am confused.
--Andy
Observatorio de la Ballona
CDK 12.5, NP-101, C-11
AP-1200, AP-900
ST-10 XME, CFW-8, Astrodon v2 filters
Pyxis Rotator, TCF Focuser
« Reply #1 on: 2007 October 10 00:10:55 »
Hi Andy,
Of course there should be no difference, other than small ones due to roundoff errors.
Could you please save your processing as a PSM file and post a link to it? Also, we'd need to have access to at least a significant crop of the original 16-bit image.
Offline andyschlei
« Reply #2 on: 2007 October 11 14:32:52 »
I'll post the PSM and images tonight.
AP-1200, AP-900
Offline andyschlei
« Reply #3 on: 2007 October 11 19:59:14 »
Here is the data documenting my problem.
PSM file:ftp://ftp.obsballona.net/NRProblem/GREYCstoration.psm
Note that I only changed the iterations to 3 and set it to do the channels separately.
16 bit integer before (link is the FITs)
16 bit integer after
32 but floating point before
32 bit floating point after
All of the files are available at ftp://ftp.obsballona.net/NRProblem/
--Andy
AP-1200, AP-900
Offline andyschlei
« Reply #4 on: 2007 October 11 22:13:57 »
One other thought.  The problem of over blurring occur when the number of iterations is greater than 1.
AP-1200, AP-900
Offline David Serrano
« Reply #5 on: 2007 October 12 04:05:14 »
I can confirm this behaviour, in both images and previews. It may be normal but I think it's worth pointing out that it takes nearly 3 times as much time to process the 32 bit floating point image.
Edit: oops, forgot to mention that I tested it with version 01.00.45.337.
[I don't get annoyed when corrected, english corrections are welcome as private messages, if you like :P]
 David Serrano
« Reply #6 on: 2007 October 12 06:02:29 »
Hi Andy and David,
Indeed this was a bug - thank you for catching it.
I have fixed it; please refer to this thread on the Announcements section.
« Reply #7 on: 2007 October 12 08:01:52 »
Fixed here. Good job :).
 David Serrano
Offline andyschlei
« Reply #8 on: 2007 October 12 11:24:20 »
I'm happy that I was able help by finding this problem.
Great to see it fixed....
AP-1200, AP-900
