Author Topic: OSX Lion 10.7 ? Finally, how runs PI under this new OS  (Read 3077 times)
Offline Philippe B.
    • CIEL AUSTRAL
Hello
During summer, some PI users complained a little about some bugs under OSX Lion.
Right now, under 10.7.1 are 64 and 32 bits version of PI working fine ?
I would like to update my MacPro soon.
Thanks !!!
Philippe
Hans Pleijsier
  • Guest
Re: OSX Lion 10.7 ? Finally, how runs PI under this new OS
« Reply #1 on: 2011 October 07 11:09:13 »
32bits under Lion here, no problems. Have not tested entire toolset though ....
Offline Lex
  • We do it at night...
« Reply #2 on: 2011 October 08 07:14:09 »
I run PI 32 bit under OSX Lion, works fine, the only things that are negative are some graphic problems for example when dragging content the window does strange things...
Also i think there is a problem when you select "overwrite existing files" in the staralignment procedure, then it saves the files with a postfix but doesn't replace the original ones...
This is a bit annoying because you have to manually erase the original files...
Otherwise the 32bit one works fine and quick without itches.
Cheers
Lex
Clear Skies!!
Lex
