Author Topic: Sharpless SH2-171 (DSLR Ha-RGB composite)  (Read 3499 times)
Offline Christoph Puetz
    • Fotos
« on: 2011 October 02 16:12:58 »
Dear PI users,
here is another DSLR widefield photo: Sharpless SH2-171.
Medium size:
http://www.ccdsky.eu/Astronomy/slides/f-sh2_171_hargb.html
Flickr large size (labeled):
http://www.flickr.com/photos/cpfoto1964/6197794490/in/pool-387956@N23/
Ha-alpha photo taken at 16/August/2011.
Canon EOS 450d, modified, Halpha Clip Filter 12nm bandwith
Exposure 11x15 minutes
Canon 200mm/f 6.3 lens.
RGB photo taken at 22/Sep/2011:
Canon EOS 450d, modified, Astronomik CLS Clip Filter
Exposure 20x10 minutes
Canon 200mm/f 5.6 lens.
Feedback is always welcome.
Christoph
Kind regards,
      Christoph
Canon EOS 500d,
PixInsight, PHD-Guiding
private URL: www.ccdsky.eu
astropixel
  • Guest
Re: Sharpless SH2-171 (DSLR Ha-RGB composite)
« Reply #1 on: 2011 October 03 23:27:19 »
DSLR RGB Ha 8)
Christoph. I notice different apeture for each session. For my learning was this intended, and do you think the lens performs better at f/6.3.
    • Fotos
« Reply #2 on: 2011 October 04 05:16:38 »
Hi Astropixel,
this was intended !
If I use the astronomik ha-alpha clip filter system it is quite hard to focus the lens on a star at all (it is a Canon 70-200 EF/4 "white series" lens) as the transmission is quite low. So I can focus only on the brightest(!!) red(!) stars (i.e. Beteigeuze, Arcturus, ....). Therefore I stop down the lens to have also some smaller stars sharp for sure.
If I don't use the clip filter system there is no notable difference in the performance between f/5.6 or f/6.3. But compared to open aperture (f/4) it is better to have it at f/5.6. Although this Canon lens is quite good at 70mm and 200mm focal length you sometimes see loss of sharpness at the edge of the field.
This can be increased by stopping the lens down.
Taking H-alpha fotos with a DSLR is not as comfortable as a cooled CCD, of course (but for me a
DSLR is more affordable  ;))
You have to take exposure times > 15 Minutes for 1 shot (even better 20-30 minutes) and I found
that debayering with the super pixel method gives somewhat besser results. Also take enough
dark frames as the Canon DSLRs produce lots of noise (esp in summer).
If you are interested, I could send you some example raw files to experiment with  ....
Christoph
Kind regards,
      Christoph
Canon EOS 500d,
astropixel
  • Guest
« Reply #3 on: 2011 October 06 01:03:27 »
Thanks Christoph. By all means. Some new data would be nice to experiment with :)
    • Fotos
« Reply #4 on: 2011 October 12 09:49:16 »
I uploaded the raw files to a online storage server. You could send me a PM with your Email and I will "invite" you for download!
Kind regards,
      Christoph
Canon EOS 500d,
