Author Topic: New Global Action: STF AutoStretch  (Read 15384 times)
« on: 2011 September 29 12:58:58 »
Hi all,
Today we have released an update to the IntensityTransformations module that introduces a new feature to the ScreenTransferFunction (STF) tool: The STF AutoStretch global action.
This action computes and applies an automatic screen stretch function to the active image. STF AutoStretch can be triggered by pressing the Ctrl+A keyboard combination (Cmd+A on Mac OS X), or by clicking the corresponding tool button on the Image tool bar. This feature has been requested by a number of users on this forum:
http://pixinsight.com/forum/index.php?topic=3328.0
I hope you like it!
Re: New Global Action: STF AutoStretch
« Reply #1 on: 2011 September 29 16:08:22 »
this is welcome news since autoSTF with uncoupled channels is the first thing i always do.
i hate to ask this, but... is there a reason why we can't have control-a on the mac as well? because i am an emacs user, i use unix style keyboards and i have the control key in the "right" place. it's a lot easier than using command (or control, which is in the wrong place on PC keyboards...)
maybe it's a wishlist item to be able to remap any keyboard shortcut in pixinsight?
« Reply #2 on: 2011 September 30 10:57:37 »
Technically, there is no reason at all. However, a large majority of Mac users know nothing about UNIX and UNIX-style-anything --more at the contrary, they tend to get scared by these four letters together :)
The standard practice when porting Linux/UNIX/Windows applications to Mac OS X is to replace Ctrl with Cmd, and this is what I tend to do unless the corresponding keyboard combination is already being used for other purpose on Mac OS X.
I know this is a very necessary feature. It is in the to-do list, but given the priorities that we have now, don't expect to see it implemented in the short term.
« Reply #3 on: 2011 September 30 11:18:24 »
understood, thanks for all your hard work. i can live with it in the meantime :)
Offline jmtanous
« Reply #4 on: 2011 September 30 14:37:35 »
Gracias Juan!
This is a welcome addition!
Jose
Offline Yuriy Toropin
« Reply #5 on: 2011 October 01 03:19:17 »
Thanks a lot for this improvement!
Could couple of the next steps be done in the same direction?
1. It will be logical if next CTRL + A or click on corresponding tool button will "Reset" STF to non-stretched state, Stretch - Reset - Stretch - Reset - ... ;
2. Even clicking CTRL + A could be boring...
Could "Auto Apply" feature be added to STF? If it will be turned ON then there will be no need in first CTRL + A click after new image will be opened, after that CTRL + A will work as expected, first click will "reset" (see #1), second will stretch, etc.
Thanks!
Offline NKV
« Reply #6 on: 2011 October 02 03:25:37 »
Hello Juan.
Can you show sources code ?
Why you don't save globally user preferences which set via dialog "STF Auto Stretch Parameterd" ?
Best regards,
Nikolay.
« Reply #7 on: 2011 October 04 02:40:28 »
Hi Yuriy,
There is already a keyboard combination reserved to reset STF: Ctrl+F12
There is also a tool button on the ScreenTransferFunction interface window that can be used to the same purpose; it is the standard Reset button that you can find at the bottom right corner of most tools.
From my experience, applying STF AutoStretch automatically upon opening images would create much more problems than solutions. It is also somewhat incoherent with important design patterns in PixInsight (don't give the user false impressions about the raw data).
There is now a script that applies AutoStretch to all open images. I wrote it in response to the wish list thread that you mentioned, but I hadn't the time to finish it appropriately. You'll find this script on the Process Explorer window: Scripts > Utilities > AutoSTF. Right now this script is very rough (it just applies AutoStretch to all open images and can't be interrupted), but it can be refined and polished with a GUI. I think this script is the best way to implement the functionality that you are describing.
« Reply #8 on: 2011 October 04 02:46:06 »
Can you show source code ?
Sure. Right now I have no access to the source code of this module, but later I'll send it to you.
Why you don't save globally user preferences which set via dialog "STF Auto Stretch Parameters" ?
I'll add this functionality in the next version.
« Reply #9 on: 2011 October 04 03:14:45 »
I am using Ctrl-A very frequently now. I very nice extension...
Offline RobF2
  • Rob
    • Rob's Astropics
« Reply #10 on: 2011 October 04 04:02:45 »
Yes, thanks so much for adding this in Juan.
F12 is a handy on/off too now I see after you've first done a "Ctrl-A".
Top stuff  8)
Rob's Astropics
Offline NKV
« Reply #11 on: 2011 October 04 23:09:34 »
Thank you.
Can you say in advance: if user set some parameters in the interface "STF Auto Stretch Parameters" it will be used via Ctrl+A ?
« Reply #12 on: 2011 October 05 22:29:00 »
Hi Juan, thanks for answering!
...you know, [F12] is too far from [A] button to consider STF On/Off switch as really smooth thing now.
Standard Reset button doesn't help a lot, aim mouse is longer then just click CTRL+A for other time.
My proposal will also save CTRL+F12 for other use...
Quote from: Juan Conejero
Thanks for pointing me out to this script!
Offline troypiggo
« Reply #13 on: 2012 January 23 02:57:43 »
I must be doing something wrong on my Mac.  Cmd-A does the autostretch, but I tried both Cmd-F12 and Ctrl-F12 and neither reset the stretch   ???
Edit: Never mind, just found it out by right-clicking on window, Ctrl-Opt-S does it.  Must've changed in more recent versions?
« Last Edit: 2012 January 23 03:25:00 by troypiggo »
