Author Topic: HaRGBCombination Script  (Read 120501 times)
Offline Ioannis Ioannou
Re: HaRGBCombination Script
« Reply #75 on: 2013 January 22 12:12:17 »
Yap, this true->false mistake is mine, should be changed (BTW I did not noticed the problem at 1.7, it was accepted as is with the previous version).
I will not be able to upgrade to RC2 and test soon, I'm currently traveling for business to the other side of the globe (and suffering from heavy jet lag :( ). My time is very limited and I will not be able to test until early February.
Other people that are using the script ?
Clear Skies
John (Ioannis)
FSQ106N+Robofocus+QHY-22+SX USB wheel+Baader filters
SX OAG+DSI Pro guiding a NEQ6
PI for the rest :)
Offline Harry page
« Reply #76 on: 2013 January 22 12:58:01 »
Have tested the script with Juan's bit
Script runs ok , but the output image is no longet linear  :o
Harry
Harry Page
Offline Lex
  • We do it at night...
« Reply #77 on: 2013 January 24 12:30:50 »
Hi guys,
has anybody tested the script with RC3? I do not know what I did wrong but my MacBook shows the error code attached.
Normally the scripts should start without opened pictures? Has there got to be be an update for the scripts?
Btw, I have also have this problem with aberration spotter?
Or is there a new way to incorporate those magnificent scripts?
Thanks  ;)
Clear Skies!!
Lex
Offline Harry page
« Reply #78 on: 2013 January 24 12:33:30 »
Images have to be open when you start the script
Harry
Harry Page
Offline Lex
« Reply #79 on: 2013 January 24 12:54:25 »
Hi Harry,
I think I am sitting on the line; I opened some pictures but the error remains  ???
Clear Skies!!
Lex
Offline Harry page
« Reply #80 on: 2013 January 24 13:00:06 »
Try this version
Does not give out linear images - need someone to help here though
Harry
Harry Page
Offline Lex
« Reply #81 on: 2013 January 24 13:05:10 »
Harry,
yep, thanks a lot; this one is working  :laugh:
Is there a difference compared to the other one?
Clear Skies!!
Lex
Offline Harry page
« Reply #82 on: 2013 January 24 13:09:37 »
There was a mistake juan spotted , I just typed it in  :laugh:  ( look a few posts back )
Harry
Harry Page
Offline Jules
« Reply #83 on: 2013 February 23 06:36:43 »
I copied the above script into the Pixinsight/contents/src/scripts folder on my macbook pro, but PI 1.8 RC3 does not see this script nor does 1.7. Can anybody make out if I have made a blunder with this please?
OS X 10.8.2
Julian
Offline ugatza
« Reply #84 on: 2013 February 23 16:43:33 »
It doesn´t work the link to download the script?
« Reply #85 on: 2013 February 24 02:57:39 »
Use Script/Feature Scripts... to register scripts.
Offline Jules
« Reply #86 on: 2013 February 24 03:17:39 »
Thanks very much, thats worked!
Regards
Julian
« Reply #87 on: 2013 February 24 10:41:37 »
ugatza which link you tried? The one Harry posted just a few topics above (which is the latest) works, I just tried.
BTW, Juan, will you final include it in 1.8  ? (I admit it, I didn't tried any 1.8 RC yet, no time :( )
Clear Skies
John (Ioannis)
PI for the rest :)
Offline ugatza
« Reply #88 on: 2013 February 24 12:37:59 »
Yes, finally I´ve tried with the one Harry posted and works, at least in my pc. Later will try in my notebook. Thank you.
Offline lucchett
« Reply #89 on: 2013 April 09 13:03:54 »
Hi ,
does someone know if the script works properly under 1.8 rc5?
Is the result linear?
Many thanks,
Andrea
