Author Topic: Wide Field Region around Bubble Nebula (Canon DSLR, Skywatcher ED80)  (Read 3328 times)
Offline Christoph Puetz
    • Fotos
Hi all,
here is a foto of the region around the bubble nebula.
Astrometry Data:
(RA, Dec) center:(348.876964543, 60.6698399976) degrees
(RA, Dec) center (H:M:S, D:M:S):(23:15:30.471, +60:40:11.424)
Orientation:104.37 deg E of N
Pixel scale:13.76 arcsec/pixel
Parity:Reverse ("Left-handed")
Field size :2.45 x 1.63 degrees
NGC 7510
NGC 7538
NGC 7635 / Bubble nebula
Skywatcher ED80, 0.7x Reducer/Flattener Südkuppel Sternwarte Peterberg.
Canon EOS450, modified, Astronomik CLS Filter, 800ASA, 10x20 minutes
http://www.ccdsky.eu/Astronomy/slides/f-versuch2_rgb.html
Any comments are welcome !
Clear Skies, Christoph
Kind regards,
      Christoph
Canon EOS 500d,
PixInsight, PHD-Guiding
private URL: www.ccdsky.eu
astropixel
  • Guest
Re: Wide Field Region around Bubble Nebula (Canon DSLR, Skywatcher ED80)
« Reply #1 on: 2011 September 25 13:19:46 »
Hi Christoph. I like the wide fields too. You have captured the nebula nicely. Do you have a higher resolution image?
I notice that you took 20 minute exposures, so I presume that you are located at a dark site - the modified camera clearly makes a difference.
    • Fotos
Hi "Astropixel",
thanks for your reply!
Here is a labeled high-res version:
http://www.flickr.com/photos/cpfoto1964/6197269583/in/pool-387956@N23/
The observatory is under an "average" rural sky, next cities are about 40km away,
at a height of about 600m above sea-level
(see www.sternwarte-peterberg.de).
I made good experiences with the "cls astronomik clip filter" system. I almost often use it during
astrofotography.
With my modified Canon EOS45d I can have exposure times to 20-45min (even with a "fast" telephoto lens).
Kind regards,
Christoph
Kind regards,
      Christoph
Canon EOS 500d,
Offline Lex
  • We do it at night...
Christoph;
Nice shot; full of details  :surprised:
Cheers
Lex
Clear Skies!!
Lex
