Author Topic: No consigo bajar las actualizaciones  (Read 4469 times)
Offline ugatza
« on: 2011 August 31 05:45:49 »
Pues eso, no consigo bajar las actualizaciones del software. Me interesaba especialmente comenzar a practicar con Gradient Mosaic Merge.
El error que me sale es el siguiente:
http://update-level.pixinsight.com/: Network error: Could not resolve host: update-level.pixinsight.com; Host not found
For that, I can not download software updates. I was particularly interested to start practicing with Mosaic Gradient Merge.
The error I get is:
Re: No consigo bajar las actualizaciones
« Reply #1 on: 2011 August 31 13:21:36 »
Try with:
http://update-devel.pixinsight.com/
it's update-devel, not update-level ;)
Offline ugatza
« Reply #2 on: 2011 August 31 15:06:09 »
He conseguido actualizar, pero no que me aparezca en el programa el módulo GradientsMosaicMerge. ¿Cómo hacerlo?
I managed to update, but I appear in the program module GradientsMosaicMerge. How?
Offline ugatza
« Reply #3 on: 2011 August 31 15:12:23 »
Ya lo he conseguido. Muchas gracias.
I've got. Thank you very much.
Offline eddiet
    • http://astroshed.com
« Reply #4 on: 2011 December 28 14:26:55 »
Hi Juan,
I'm not sure why this is, but updates fail for me with using default settings. The default path for downloads is C:/Users/Eddie/AppData/Local/Temp
The Package download succeeds, but when PI is closed and update attempted, the update fails reporting "Can't find required components". Then PI appears to shut down, but is actually still running and needs to be killed from the task manager.
I suspect a permissions issue on the path, but I don't know why as its running as admin, the folder is owned by me, and the packages were successfuly downloaded.
If I change the download path to somewhere else, it all works properly. I had this problem with the previous version and fixed it that way, but as I just erased the old PI settings for the latest version, it has just happened again and I thought I'd better let you know before I forget all about it...again...
Eddie T.
Offline eddiet
« Reply #5 on: 2011 December 28 14:34:41 »
Sorry to hijack the thread, it was unintentional. Please delete my posts and I'll repost in a more-appropriate location. Oops..
Eddie
Eddie T.
Offline Santi
« Reply #6 on: 2015 June 20 11:08:41 »
Tengo un problema con las actualizaciones:
¿cómo puedo solventarlo?
Gracias
