Author Topic: Black image after ImageCalibration, when input is RAW  (Read 3998 times)
Offline zvrastil
    • Astrophotography
« on: 2011 August 30 10:55:03 »
I have strange problem with ImageCalibration. When I apply it to RAW (CRW) images, it produces completely black (0) image. When I first convert RAW image to FITs using BatchFormatConversion script, it produces nice calibrated image. Is there some piece of knowledge I'm missing?
Attached image shows my options. I integrated darks without bias subtraction, so darks need to be calibrated. Flats were already bias-subtracted before integrating master flat.
thanks, Zbynek
Re: Black image after ImageCalibration, when input is RAW
« Reply #1 on: 2011 August 31 13:45:50 »
Hi Zbynek,
I haven't seen this problem before. All settings look perfectly normal, so you probably have discovered a bug. Could you upload a couple of lights and your master bias, dark and flat frames? I guess it's the only way I can understand what happens. Thanks!
Offline zvrastil
    • Astrophotography
« Reply #2 on: 2011 August 31 23:11:54 »
Sure Juan,
I'll upload them to pixinsight FTP this afternoon.
regards, Zbynek
Offline zvrastil
    • Astrophotography
« Reply #3 on: 2011 September 01 10:42:08 »
Hi Juan,
images are uploaded on PixInsight FTP as ImageIntegration_problem.tar.bz2
cheers, Zbynek
« Reply #4 on: 2011 September 02 07:48:15 »
Thanks a lot Zbynek. I'll take a look later and will let you know what I find.
