Author Topic: DPSF: how do I pick the same set of stars for analysis in second image?  (Read 4240 times)
I stacked my image twice, eliminating a few so-so frames in the second go around. I picked a bunch of stars in the first image and saved the average PSF data in a text file (unfortunate that PI won't allow you to keep that result window around). I registered the second frame to the first to make sure they are identical. I saved the processing icon of the first PSF process and tried to apply it to the second image. That does not work. I was hoping it would work ala DBE but it doesn't. Am I doing it wrong or is this a limitation of the process? I can't re-apply the process icon to the original image either.
Thanks!
