Author Topic: August 2011 Contest Images  (Read 10087 times)
Offline Javio
  • Moderator
    • PixInsight
« on: 2011 August 01 01:50:09 »
The August 2011 PixInsight Monthly Astrophotography Contest is open. Please use this post ONLY to submit your images. Good luck!
Javier Sanchis Muñoz
Re: August 2011 Contest Images
« Reply #1 on: 2011 August 01 17:49:16 »
Hola,
4 horas y 22 minutos, pero no de exposición. Ese fue el tiempo que le tomó a la PC con win32 y 2GB para integrar las
51 imágenes de la Canon 5D Mark II.
El objeto es Omega Centauri y lo sacamos en colaboración durante el estreno del nuevo Taka 106 de Ezequiel Bellocchio.
Procesado 100% en Pix 1.7 y todos los detalles, parámetros y foto en mayor tamaño en los siguientes links:
En Castellano: http://proxima-sur-fotos.blogspot.com/2011/07/ngc-5139-detalles-del-procesamiento.html
In English: http://proxima-sur-fotos.blogspot.com/2011/07/ngc-5139-details-of-processing.html
Participamos, Ezequiel Bellocchio, Andrés Vattuone, Leonardo Julio y Alejandro Tombolini
Saludos.
Alejandro.
4 hours and 22 minutes, but not exposure time. It was the time that took to the PC with win32 and 2GB to integrate
 51 images from Canon 5D Mark II.
The object is Omega Centauri and we took it in collaboration during the first light of the new Ezequiel Bellocchio' Takahashi 106.
Processed 100% in Pix 1.7 and all the details, parameters and full resolution in the following links:
Colaboration: Ezequiel Bellocchio, Andrés Vattuone, Leonardo Julio y Alejandro Tombolini
Alejandro.
Offline Oleg Bryzgalov
    • My astrophotosight (in Russian, sorry)
« Reply #2 on: 2011 August 06 09:04:19 »
Ghost nebula Sh2-136 in Cepheus
This picture was photographed on July 6-8, 2011 in the Crimea Ukraine) during the festival of amateur astronomy, "Southern Nights 2011" (height of 600 m above. sea level)
Good weather conditions, dark sky. FWHM from 1.4 to 1.9 arcsec.
Equipment: reflector S&D 254 mm. f/4.7 (New carbon tube), Mount WhiteSwan-180, camera QSI-583wsg, Tevevue Paracorr. Off-axis guidecamera Orion SSAG.
LRGB filter set Baader Planetarium. L: 20x600 sec., RGB: 10x600 sec. each filter, all unbinned.
Calibrated and processed using PixInsight 1.7. Just little final touch in Photoshop CS5.
Process workflow:
L channel:
Calibrate, star align, image integration using Linear Fit Clipping
Dynamic crop
DBE
Histogram transformation
HDRWT
RGB channels:
Combine  channels to RGB image
Dynamic crop
Background Neutralisation
Color calibration (manual, using data from eXcalibrator)
LRGB combination
SCNR
ACDNR
Finally, adjust levels in Photoshop (I have so far is more convenient)
Direct link to full image: http://olegbr.astroclub.kiev.ua/files/astrofoto/vdb141/vdb-141_sh2-136_full_v3.jpg
Here cropped center, size 50%
Offline Giorgio
« Reply #3 on: 2011 August 07 23:28:19 »
Hello.
This is the Nebula M27 cost. Vulpecula made on June 27 and on July 21/27/29. (2011) from the city center.
Telescope Takahashi FS128 f/8
CCD Apogee U8300
filters Optec
RGB 120' each channel bin2
Halpha 8nm 200' bin1
OIII 8nm 60' bin1
Calibration and Alignment made with PixInsight
Deconvolution with dynamic PSF only Ha and OIII
Combination with PixelMath: R_Hax8, V_OIIIx4, B_OIIIx3, linear fits,
DBE, RGBWS, BackgroundNeut. , ColCal, ATWT small scale for noise, histograms, HDRWT B3Spline 6 and  4 levels mask dering enabled, ACDNR,istogram, reduce stars with Morph.T, curves, ColorSaturation with a mask, LocalHistogramEqualization with mask.
It 's all.
Giorgio.
http://www.flickr.com/photos/53758843@N03/6016989539/
« Last Edit: 2011 August 07 23:44:57 by Giorgio »
Offline Sean
    • My Personal Website
« Reply #4 on: 2011 August 14 11:11:15 »
IC1318 - The Gamma Cygni Nebula in Ha
Takahashi FSQ106EDX
AP900 Mount
Astrodon 3nm Ha Filter
QSI 583wsq
27 x 10 minutes total imaging from the Rogue Valley in Southern Oregon
Captured with Images Plus 4.0, focus control with RoboFocus
Guided with PHD
Processed entirely in PixInsight 1.7
Calibration with Bias, Darks, and Flats
Star Alignment
Histogram Transform
Combined Star and Large Scale Structure mask using AWT and PixelMath
Large Scale Structure enhancement with AWT
Noise reduction on background with ACDNR
Local Histogram Enhancement
Slight Curves Adjustment
Link to a full size image:
http://www.drakevisual.com/picture/ic1318ha_3d.jpg?pictureId=10831042
« Last Edit: 2011 August 14 12:00:00 by Sean »
Offline jeffweiss9
« Reply #5 on: 2011 August 14 14:19:36 »
The pelican in the Pelican (IC5070):
http://www.astrophotogallery.org/member-galleries/p7866-ic5070-pelican-nebula.html
2.8 hr LRGB
Scope: APM 130/780 f/6 LW CNC II
Mount: Takahashi EM-200 Temma2
Camera:SBIG ST-2000XM Astrodon Gen2
Location: Henry Coe State Park (SF Bay Area), California
Dates: 7/30/11, 8/2/11
Exposure: L:10x8min RGB:3x7x4min(2x2)
Acquisition S/W: CCDSoft v 5, TheSky6, ASCOMTemmaDriver
Processing S/W: PixInsight v 1.7, Photoshop CS2
Processing:
Calibration in PixInsight (Vicent Peris document)
Registration of calibrated lights with StarAlignment
Stacking with ImageIntegration
RGB:
ChannelCombination
Background Neutralization
Dynamic Crop
DBE
ColorCorrection
HistogramStretch plus HistogramTransformations (2)
L:
Dynamic Crop
MakedStretch plus Histogram Transformations (2)
Very slight CurvesTransformation
DynamicAlign with RGB
LRGBCombination
HDR Wavelet Transformation 4 levels only
ACDNR small scale (2,3) only
Extract Luminance and apply as mask for Saturation increase using
CurvesTransformation/Saturation for strong boost to stars
Invert mask and give very gentle saturation boost to H2 in Pelican
Take 16-bit tif to PS CS2 for final cleanup and printing:
Carboni 'make stars smaller'
Very gentle final curve with some raising of the background to survive jpg conversion
Some highpass filtering in high-SNR areas where the data supported it  (Tried AWT in PI
to accomplish the same goal but was unsuccessful - maybe next time).
Print & make jpg with sRGB profile
(Working toward doing everything in PI but not quite there yet).
Hope you like it.
-Jeff
