Author Topic: PI 1.7.0 - macosx x86 (32-bit) : out of memory  (Read 2665 times)
« on: 2011 July 27 11:47:32 »
despite top showing that the pixinsight process is using around 2.6GB, i keep getting out of memory errors while working. i've got about 10 DSLR images open, and some of them have quite a long processing history, but i don't think i've ever seen this behavior before in the past. it was very likely that i'd get the out of memory error while integrating 50+ images, but now i'm seeing it all the time when just trying to do atrous or other operations.
anyone else with this behavior? the 64-bit version is still too unstable to use - eventually i get a cascade of process apply triangles when i drag the triangle to an image, and that's followed by a "low level API error" while trying to lock an image for a process application.
