Author Topic: VS2010  (Read 6316 times)
Offline David Raphael
    • Astrofactors CCD Cameras
VS2010
« on: 2011 July 23 10:18:18 »
Hi Juan -
I remember you mentioning that VS2010 is now supported - how do we migrate existing projects?
Thanks!
Dave
David Raphael
Re: VS2010
« Reply #1 on: 2011 July 23 11:00:00 »
I went ahead and took a stab at migrating...
I'm getting this error:
1>PCL-pxi.lib(Dialog.obj) : error LNK2038: mismatch detected for '_ITERATOR_DEBUG_LEVEL': value '0' doesn't match value '2' in CameraData.obj
I'm actually getting that error for all of the *.obj
I'm guessing that the PCL-pxi.lib is built in release mode but my project is in debug mode.  Is there something obvious I need to do to?
David Raphael
Re: VS2010
« Reply #2 on: 2011 July 23 11:14:12 »
My wife says I always like talking to myself...I guess she is right :-)
So here is the solution to my problem - the compiler needs this:
-D_ITERATOR_DEBUG_LEVEL=0
I haven't tried debugging...so I am not sure if this affects that...I think it is not related.
David Raphael
Re: VS2010
« Reply #3 on: 2011 July 24 03:43:14 »
Hi Dave,
Migrating existing VC2008 projects should be automatically managed by VC2010. In theory you just have to open the old project with VS2010 and follow the proposed steps.
However I strongly recommend you recreate the entire project using the standard Makefile Generator script in PixInsight. This will rebuild your projects and makefiles for all supported platforms from scratch.
I have no idea what the _ITERATOR_DEBUG_LEVEL thing is; I haven't seen it before. I don't use any MS products at all except to build PixInsight and test it on Windows, which I only use for the same reason. Again, if you rebuild your projects with the Makefile Generator script this won't happen.
Offline zvrastil
    • Astrophotography
Re: VS2010
« Reply #4 on: 2011 July 24 06:55:00 »
Hi Juan,
if you remember, this is the problem I wrote you about in a mail. It only happens with VS2010 and only compiling in Debug. It happens even with standard sample projects, including SandBox. As far as I was able to google it, it's problem of linking debug binaries agains PCL libraries, which are release. I was not able to find any solution for it, so I still do my PCL development in VS2008.
regards, Zbynek
Re: VS2010
« Reply #5 on: 2011 July 24 10:02:24 »
Zbynek,
My screenshot shows the fix, but here is a link to another - http://stackoverflow.com/questions/5727815/how-to-set-iterator-debug-level-in-vs2010
I have now been compiling all my different modules in VS2010 without any issues.
Dave
David Raphael
Offline zvrastil
    • Astrophotography
Re: VS2010
« Reply #6 on: 2011 July 24 23:49:04 »
Hi Dave,
thanks for the link. Seems I should've spend little more time googling :).
regards, Zbynek
