Thanks guys for your nice words.
The two arrow buttons are to regenerate (recalculate) PSFs. The single arrow button will regenerate the currently selected stars (you can select stars either on the list or by clicking them on the image). The double arrow button regenerates all stars. PSFs are recalculated for the current "PSF Model Functions".
Some tips:
- PSFs can only be (meaningfully) measured on linear images.
- Use the STF tool with automatic screen stretch to work with DynamicPSF.
- Normally, our goal is to determine the "average PSF" of an image. This task involves some "art" and requires some experience to be done properly. Not all stars are valid for this task:
* Saturated stars are useless. Avoid stars for which the amplitude parameter (A) is close to or larger than one. Ideally, A should not be larger than 0.3 or 0.5.
* Too dim stars cannot be fitted properly. This happens mainly because for too dim stars the wings of the fitting function (Gaussian or Moffat) are undistinguishable from the local background.
- If the rotation angle (theta) and/or the aspect ratio (r) don't stabilize for a set of 5 - 10 good star fittings, then you should fit circular functions. This happens with undersampled images and also under high noise levels.
- Click the Sort button (down arrow) to sort the set of fitted stars by mean absolute deviation (MAD). If the stars at the bottom have comparatively poor fitting quality (for example, you get 1.0e-04 at the top of the list and 1.0e-02 at the bottom), remove the worst fittings and, if necessary, choose different stars for which the fitting quality improves.
- Watch out for round and little objects of stellar appearance that may not be stars. This happens very frequently on deep images with small background galaxies. Normally these objects can be detected because they tend to be fitted with much larger functions (watch the sx and sy parameters) as they usually have much larger dispersion than true stars.
- Once you have a sufficiently large set of reasonable PSF fittings (say from 10 to 50, depending on the image), click the Export button (little blue sphere) to generate an average PSF as a new image window. The generated PSF is normalized, that is, it uses the whole [0,1] range and is suitable to be used with the Deconvolution tool (in External PSF mode).
- If you want to compare FWHM estimates between images, you probably need to use the same fitting function in all cases: either Gaussian or a fixed beta Moffat. Bear in mind that each function will provide a different FWHM even for the same star. Or you can compare average PSFs obtained as above; you can fit a PSF for an average PSF
Hope this helps.
