Author Topic: combination of H alpha with R/L using the maximum operator  (Read 4314 times)
Offline kwiechen
Hello,
can anyone show me the pixelmath equation to combine H alpha for example with R using the maximum operator? Is it useful to apply a Linearfit before?
Or is there already an implementation of the new approach for the combination http://pixinsight.com/forum/index.php?action=post;board=5.0
Thank you very much!
Best
Kai
Offline kwiechen
Re: combination of H alpha with R/L using the maximum operator
« Reply #1 on: 2011 August 28 04:48:54 »
Hello,
I have tried to combine H alpha data with (rather poor and noisy) broadband data using the technique described here http://pixinsight.com/tutorials/narrowband/theory/en.html. The resulting continuum map looks very strange and so I have stopped this.
Then I have tried http://pixinsight.com/forum/index.php?topic=1754.msg10429#msg10429 to combine Ha/R and Ha/L using the max operator from pixelmath. As I am using the Astronomik LRGB filter set, I think it may be appropriate to blend some H alpha data in B and G to simulate H beta too.
I have tried
max( (blend_factor * Ha + (1 - blend_factor * Broadband), Broadband )
to control transfer of H alpha into broadband data without affecting star size after aligning the background using the AutoHistogram tool (blend_factor 0.8 for R, L, 0.1 for B, 0.05 for G for example).
http://img51.imageshack.us/img51/4371/ic1848halharhaghab.jpg
Best
Kai
