Author Topic: selecting a part of the picture to process  (Read 6782 times)
Offline cherodotou
« on: 2011 July 05 20:05:47 »
Hello,
This is a picture of a brick from a scanner. I want to process just the brick in PixInsight, how can I do this? Bear in mind that the edges of the brick have an irregular and curvy shape.
Thank you.
Re: selecting a part of the picture to process
« Reply #1 on: 2011 July 05 23:45:15 »
Create a mask that selects the brick, and apply it to the brick image. After that, all operations are limited to the brick pixels.
« Reply #2 on: 2011 July 06 02:40:46 »
To create the mask, just extract the luminance, and apply a threshold (Binarize process).
I think that for most operations, you'll be fine with the mask. There may appear some boundary artefacts if you use convolutions or morphological filters, but in general it won't be a problem.
Oh, btw, if you want to extract statistical parameters, the easiest way is to create a preview inside the brick.
