Author Topic: Gradient Domain Operations, take 3 (was: Gradient Domain HDR Compression)  (Read 35780 times)
Offline David Raphael
    • Astrofactors CCD Cameras
I tried compiling this on OS X, and I ran into some issuese...
...I'm only pasting some of the error...
g++ -arch i386 -Xarch_i386 -mmacosx-version-min=10.5 -fPIC -dynamiclib -install_name @executable_path/GradientDomain-pxm.dylib -L"/Users/draphael/PCL/lib/macosx/x86" -L"/Applications/PixInsight32.app/Contents/MacOS" -o "/home/georg/Gradients/macosx/g++/x86/Release"/GradientDomain-pxm.dylib ./x86/Release/GradientsBase.o ./x86/Release/GradientsHdrCompression.o ./x86/Release/GradientsHdrInstance.o ./x86/Release/GradientsHdrInterface.o ./x86/Release/GradientsHdrParameters.o ./x86/Release/GradientsHdrProcess.o ./x86/Release/GradientsMergeMosaic.o ./x86/Release/GradientsMergeMosaicInstance.o ./x86/Release/GradientsMergeMosaicInterface.o ./x86/Release/GradientsMergeMosaicParameters.o ./x86/Release/GradientsMergeMosaicProcess.o ./x86/Release/GradientsModule.o ./x86/Release/RgbPreserve.o -lpthread -lPCL-pxi
Undefined symbols for architecture i386:
  "global constructors keyed to _ZN3pcl5AlphaEi", referenced from:
      anon in GradientsBase.o
  "global constructors keyed to _ZN3pcl23GradientsHdrCompressionC2Ev", referenced from:
      anon in GradientsHdrCompression.o
  "pcl::GradientsHdrCompression::GradientsHdrCompression()", referenced from:
      void pcl::GradientsHdrEngine::Apply<pcl::UInt8PixelTraits>(pcl::Generic2DImage<pcl::UInt8PixelTraits>&, pcl::GradientsHdrInstance const&)in GradientsHdrInstance.o
David Raphael
Sorry, can't help you with this.
Is this with the PCL version released today? I did not yet try it with that one.
Maybe you can use the version that Juan provided in http://pixinsight.com/forum/index.php?topic=3211.msg22047#msg22047
Offline Harry page
Hi Georg
Have you made any head way  ;)
Harry
Harry Page
The one that you linked worked.  I'll test it out and let you know how it goes!
Dave
David Raphael
Isn't Juan's version avalaible through the "development" repository (for Mac)?
Nope - I added the repository, and it didn't seem to find anything.  I'm running the 32-bit version...
David Raphael
And it isn't working on my Windows 64-bit install either...
David Raphael
I guess it is because the repository indicates an older version of PixInsight core:
   <platform os="windows" arch="x86_64" version="1.7.0.695:1.7.0.698">
      <package fileName="20110703-windows-x86_64-module.zip"
               sha1="9407cdb8534cadf6d272a6a72cfcafa925424e8d"
               type="module"
               metadata="20110703-module"/>
   </platform>
I am running 1.7.0.0702
/d
David Raphael
Sorry for the mistake —I simply forgot to update the development repository after the release of 702. This is now fixed and should work correctly; let me know otherwise.
No Problem!
The module worked great so far for me.  I attached a screenshot of a sample mosaic I'm working on.
David Raphael
Hmmm... I feel that are still some unmatched features, or at least, you can tell differences in color. Georg, is the merge done only in the luminance?
Hi David,
not bad! Thanks for testing this. Some questions and remarks:
- what size is this mosaic? It appears to be much larger than anything I tried on my modest Linux machine.
- how long did the process run for this mosaic? Do you feel that runtime is acceptable?
- Some of your unmerged images have strong background gradients close to their borders. These are still visible in the merged images. I guess that either a DBE (before merge) or removing this part of the images would improve the result.
Hi Carlos,
no, the merge happens separately on each color channel. I suppose that the remaining artifacts are caused by the strong background gradients mentioned above.
Yes... so, be need to merge the gradients of those images... I'm wondering if there could be a multiscale approach to this.
Hi David,
This is a 6 panel mosaic that is approx 7000 x 7000
About 5 minutes - definitely acceptable
Yea - it was a quick and dirty effort.  I am redoing it now and I will let you know how that goes.
David Raphael
Well - that didn't go very well...
I've attached the result of my efforts - this time I removed the gradients prior to using the Merge Mosaic!  But something must be wrong with how I am doing it...
Let me know what you think.
David Raphael
