Author Topic: Documentation Browser overlays Process Explorer  (Read 3287 times)
Offline beecee
« on: 2011 June 26 11:36:35 »
Somehow I have altered the latest version of PI so that the Documentation Browser overlays half of the Process Explorer. This happens when I have the Process Explorer docked anywhere on the screen.
I believe that it somewhere in preferences because it does not do that if I initiate an addition instance of PI (with default preferences). I just can not find it.
I am using the latest version of PI with all updates applied.
Help!!
Robert Collins
http://www.flickr.com/photos/14381217@N03
Yuba City, CA
Re: Documentation Browser overlays Process Explorer
« Reply #1 on: 2011 June 26 14:28:20 »
Hola Robert,
Si entiendo bien deberías hacer click en el borde de la ventana del Process Explorer y expandirla hasta que puedas ver las dos
flechas azules en la base de la ventana y hacer click ahí para cerrarla.
Hi Robert,
If I understand well you should click in the rim of the window of Process Explorer and expand it until you could see the two
blue arrows at the bottom of the window and then click there to close it
Alejandro.
Offline beecee
« Reply #2 on: 2011 June 26 15:26:07 »
Thanks Alejandro. I was able to drag the Documentation Browser frame to make it larger and be able to see the double arrows at the bottom. Now it works correctly. I had tried everything before without success.
Many thanks.
Robert Collins
Yuba City, CA
