While integrating flats I noticed that saving the "Integration" as 32bit IEEE 754 fits, the values' range is expanded from 0 to 1 (with the initially integrated image having values 0.23 to 0.47). This does not happen if I save the image as 32 bit unsigned integer and does not seem to create any problems with unbinned flats. But when I integrated 2x2 binned flats the IEEE 754 fits looked different from the produced integration (could be the autostretch function producing different results due to different ranges of values) but more importantly with catastrophic calibration effects. Temp_flat is the original image and temp_flat1 is the IEEE 754 saved image after auto stretching both.
What's the catch here, am I missing something obvious?
Tasos
