Author Topic: GUI elements  (Read 4272 times)
Offline FunTomas
    • Astrofoto.sk
GUI elements
« on: 2011 June 20 22:09:14 »
What is the difference between these buttons? Thank you for explaining. I couldn't find any information about it.
Re: GUI elements
« Reply #1 on: 2011 June 21 04:54:42 »
Here we go:
- New Instance icon (aka 'the blue triangle'). Click this icon and drag it to generate a new instance of a process that encapsulates all parameters currently defined on the corresponding interface window. You can drag this instance to the workspace to create a new icon, or to an image to apply the process, among other actions.
- Apply button (blue square). Click this button to apply a process to the active view. The active view is the current view (a main view or a preview) on the active window. The effect is the same as if you drag the blue triangle to the active view.
- Apply Global button (blue sphere). Click this button to execute a process on the global context of PI. Not all processes can be applied globally. When a process is executed globally, it does not apply to any particular image. For example, a process that can only be executed globally is Preferences. This process changes a number of options that affect the whole PixInsight platform —such as folders, window colors, parallel processing settings, etc.—, but it does not change any image.
Hope this helps.
Offline FunTomas
    • Astrofoto.sk
Re: GUI elements
« Reply #2 on: 2011 June 21 11:39:21 »
Thank you Juan for explanation. The blue disc icon is available at StarAlignment dialog. This icon started process of alignment on all images selected in the dialog - global action. I was wondered why these two icons worked and I can't find any difference between these two actions.
Offline Harry page
Harry Page
