Author Topic: Effect of void pcl::ImageGeometry::SelectRectangle ( int x0, ...)  (Read 4795 times)
I am wondering about the exact effect of void pcl::ImageGeometry::SelectRectangle().
- Suppose I have an Image with width 4711 and height 3333
- Image coordinates as used by PixelData run from 0..4710 for x and 0...3332 for y
- If I set  pcl::ImageGeometry::SelectRectangle(100,200,300,400), which pixel range will be affected in subsequent calls of Apply():
  1. x in range 100..299, y in range 200..399?
  2. x in range 101..300, y in range 201..400?
  3. x in tange 100..300, y in range 200..400?
I am asking because I find that  pcl::ImageGeometry::ResetSelection() would reset to range selected.rectangle.Set( 0, 0, width, height ), which assuming option 3 would be one pixel more in each direction than the image really has...
I would say that it is the first option. See how it is used in the HDRC code to perform padding.
Rectangles of integer coordinates exclude the bottom right corner in PixInsight/PCL/PJSR. This means that a rectangle with coordinates:
x0 = 100
y0 = 200
x1 = 300
y1 = 400
defines the rectangular region from {100,200} to {299,399} both points included. The row at y=400 and the column at x=300 are both excluded.
The advantage of this convention is that the width and height of a rectangle are equal to x1-x0 and y1-y0, respectively.
Note that for rectangles of real coordinates the same rule applies, but the bottom right corner is always included. This is just a consequence of the continuous nature of real coordinates, as opposed to the discrete nature of integer coordinates.
On the other hand, note that GenericRectangle's coordinate constructor is:
template <typename T, typename T1>
GenericRectangle<T>::GenericRectangle( T1 left, T1 top, T1 right, T1 bottom );
that is, it doesn't take width and height arguments, but four coordinate arguments. There is a constructor from two dimensions, namely:
template <typename T>
GenericRectangle<T>::GenericRectangle( T width, T height );
which creates a rectangle where x0=y0=0, x1=width and y1=height, that is, a rectangle anchored at the origin.
« Last Edit: 2011 June 18 13:48:08 by Juan Conejero »
