Author Topic: 1.7 DBE problem  (Read 3668 times)
Offline Cleon_Wells
1.7 DBE problem
« on: 2011 June 11 18:18:58 »
64bit Build 697 on a MacBookPro i7
When I use DBE the control pane moves behind the HST pane when I select the image.  When I execute DBE the resulting image has a blue hue.
Cleon
« Last Edit: 2011 June 12 05:24:18 by Cleon_Wells »
Re: 1.7 DBE problem
« Reply #1 on: 2011 June 17 08:22:40 »
Hi Cleon,
Yes, I am aware of this little problem with window (dis)ordering on the 64-bit Mac OS X version. It will be fixed in the next version.
As for the blue background, I really can't know what's happening if I don't see where you put your DBE samples on the original image. From what I see it doesn't seem you've covered the background well, at least on the left and upper borders of the image, but I can be wrong. Could it be misplaced samples what is yielding that blue cast?
Offline Cleon_Wells
Re: 1.7 DBE problem
« Reply #2 on: 2011 June 17 12:13:32 »
Juan, here’s is another example of DBE and the blue hue issue.
Last night between the Sun setting and the Moon rising, I got 14, iso400 120-sec subs of M51.  The only difference between the first DBE and the second DBE1 is I clicked the Sample# selector twice.
Cleon
Offline Cleon_Wells
Re: 1.7 DBE problem
« Reply #3 on: 2011 June 17 21:36:14 »
Juan, here's a example with the samples shown, the samples were automatically generated. If I manually add one more sample anywhere in the image the blue hue is removed, this example is with 1.69.
Cleon
Offline Cleon_Wells
Re: 1.7 DBE problem
« Reply #4 on: 2011 June 19 12:58:18 »
So the Blue hue is a fluke I created by not having enough samples of this image for DBE to do its magic. I watched Harry’s video on DBE
 http://www.harrysastroshed.com/pix%20videos/new/DBE/DBE.wmv
and can see that 200 plus samples can be used on this image.
I do have some questions on Symmetries, so I’ll start a new thread in PixInsight
Cleon
