John, I quickly tried the fixlines script.
If I load my previously made column defects map in to the script and press 'ok' it works. If I drag the triangle to the picture that is open then gives the 'recursive' error.
If I drag the little triangle to the desktop for a new instance, close the script, and then apply the triangle to the open picture....I get the following.
Script: Processing view: M51_B_1200s_00000196_M51
run -x -p="fixColumn,true" -p="fixRow,false" -p="position,0" -p="doColumns,true" -p="doRows,false" -p="columns,91,203,553,572,1229,1610,1947,1991,2017,2092,2950,690,378,839,959,1972,2129,2376,2612,2691,2752,2808,176,279,319,397,1540,1780,1836,1626" -p="rows," -p="average,true" --md5="dcb78cd5791d80df1a1146130c5530f9" -p="isGlobalTarget,false" -p="isViewTarget,true" -p="targetView,M51_B_1200s_00000196_M51" "$PXI_SRCDIR/scripts/fixLines.js"
Processing script file: C:/Program Files/PixInsight/src/scripts/fixLines.js
*** Error [000]: C:/Program Files/PixInsight/src/scripts/fixLines.js, line 40: Error: Image.sample(): invalid argument type: numeric value expected.
Reading swap files...
387.10 MB/s
0.141 s
Same type of thing happens when I apply to an image container.......
bud
