Author Topic: Dots resist to move in DBE  (Read 4543 times)
Offline gvanhau
« on: 2011 June 07 11:14:05 »
Hello
I'm not shure if this is realy a bug, but it could be.
The senario is working inside a proyect,  using DBE,  when I try to move a dot, the program resists a lot. (reaction is very, very, very slow and jumpy)
Placing new dots or erasing others is normal.
platform: win 7 64bit,   8G ram, phenon 4xcore 2.4Ghz.
Regards
Geert
Geert Vanhauwaert
Re: Dots resist to move in DBE
« Reply #1 on: 2011 June 07 12:08:07 »
Hi Geert,
I've noticed this behavior before and it looks like 1.7 has the same problem. I just loaded a 3000x2000 32b RGB TIFF and placed one DBE sample. I switched to 1:1 view in a window that's about 800x600 pixels. Dragging the sample very slowly works fine but large motions are problematic. CPU load remains low while I do this so I suspect there's some logic in the code that allows only a few updates per second which makes large movements problematic. I hope Juan will comment on this.
« Reply #2 on: 2011 June 07 12:09:29 »
Oh, this is on a laptop with W7 and a core i7 2G CPU. Should be plenty of horse power and as I said, CPU load is low.
Offline RBA
    • DeepSkyColors
« Reply #3 on: 2011 June 07 13:36:32 »
FWIF, I haven't noticed that "effect" (v1.7 on win7x64)
« Reply #4 on: 2011 June 07 13:38:47 »
Perhaps we're not talking about the same thing? Grab the sample with your mouse and quickly drag it left/right over the image. The sample will skip over the image. I've seen it on several systems, I'm pretty sure it's generic behavior.
Offline RBA
    • DeepSkyColors
« Reply #5 on: 2011 June 07 13:44:03 »
Yup, that's what I just did. I hadn't noticed it earlier but I don't recall ever having to drag a sample across the image or far from its original location, so I was curious and decided to try it, but again, it looked fine to me. No delay or slowmo of any kind.
« Reply #6 on: 2011 June 07 13:45:40 »
Wow, that's surprising. Thanks for trying and reporting!
Offline Gary
« Reply #7 on: 2011 June 07 14:25:14 »
Hi I just tried this on my pc win7 64bit. tried with 10 to 50 samples per row image size was 3474 x 2314 46 MB cr2 and samples dragged across the screen very smoothly.
Gary
Offline gvanhau
« Reply #8 on: 2011 June 07 21:26:11 »
Hello
Aditional info: If I begin working on a fresh image every thing goes ok, but if I open a previously saved proyect with several images (including masks) then DBE begins to stick.
Regards
Geert
Geert Vanhauwaert
Offline DarrenS
« Reply #9 on: 2011 June 07 23:47:34 »
I too have experienced this occasionally, did wonder if it was related to real time updating of the sample inclusion/rejection window on large rgb images.
Darren
