Author Topic: Minor UI Problem in DBE  (Read 2826 times)
Offline Sean
    • My Personal Website
« on: 2011 June 05 12:11:18 »
In Version 1.7 (and 1.6), Mac OS 10.6.7, 64 bit:
In the DBE dialog, Sample Generation section, when you change the number of samples per row from the default 10, the new value is not recognized unless you tab or click out of the field. A minor issue, but it has bitten me multiple times now, where I change the 10 to 30 and directly click Generate, and wonder why I still only have 10 samples per row.
By the way, in general, 1.7 64 bit Mac Version seems very good!
Sean
Re: Minor UI Problem in DBE
« Reply #1 on: 2011 June 17 08:25:25 »
Thanks Sean,
Yes, I can confirm this problem. As you see the 64-bit version is quite better in PI 1.7, but I still have to work a lot to fix many little glitches like this one. I'll try to solve most of these problems in the next release.
