Author Topic: DarkStructureEnhance Bug (even after latest Update)  (Read 3084 times)
Offline Christoph Puetz
    • Fotos
« on: 2011 June 05 04:02:20 »
Hi all,
I applied the current PI 1.7. update and I use Windows7 64bit OS.
When I try to call Darkstructure Enhance 2 times, the second call gives me these errors:
(comment: 1st call)
ProcessContainer: Processing view: Image141_clone_clone_clone
HistogramTransformation
Processing channel #0: Histogram transformation: 100%
Processing channel #1: Histogram transformation: 100%
Processing channel #2: Histogram transformation: 100%
Mask: Masking from swap files...
1.342 s
Writing swap files...
109.23 MB/s
Reading swap files...
558.73 MB/s
(comment: This is the second call!)
run --execute-mode=auto "C:/Program Files/PixInsight/src/scripts/DarkStructureEnhance.js"
Processing script file: C:/Program Files/PixInsight/src/scripts/DarkStructureEnhance.js
*** Error [000]: C:/Program Files/PixInsight/src/scripts/DarkStructureEnhance.js, line 428: Error: Sizer.add(): invalid argument type: UIObject expected.
If I save the project or if I do something else and call DarkStructureEnhance again, it will work fine again.
Kind regards, Christoph
Kind regards,
      Christoph
Canon EOS 500d,
PixInsight, PHD-Guiding
private URL: www.ccdsky.eu
Re: DarkStructureEnhance Bug (even after latest Update)
« Reply #1 on: 2011 June 17 08:11:59 »
Hi Christoph,
This is quite strange. Let me try to reproduce it before saying something useful...
    • Fotos
« Reply #2 on: 2011 June 20 07:20:40 »
Hi Juan,
thanks for the reply.
Maybe this will help you:
I can reproduce this bug now, if I load a project with many open files (say about 20-30 pictures) and many open
process aplications - so the physical memory should be used by nearly 100%.
I think this is a resource problem !!
I fact, it won't happen with only one open picture.
I you can't reproduce this, I could send you my project - which is quite large !!
Thank you in advance,
Christoph
Kind regards,
      Christoph
Canon EOS 500d,
