Author Topic: Unable to Save a Project  (Read 4419 times)
Offline sleshin
« on: 2011 June 02 15:43:17 »
Trying to see how the Project function works and find that I can't save a Project. Have done some initial processing and trying to save several images with their Histories along with several Process icons. When I hit the OK button on the Save Process dialog I get the following error:
ReadPSF: Unable to lock parameter data for read-only access: isSimmetric
and the Processing Console indicates that Writing Project fails. The ReadPSF module is installed but has not been used on the images I'm trying to save nor is it's icon on the desktop.
Obviously doing something wrong so any help learning how to use the Project function appreciated.
Steve Leshin
Stargazer Observatory
Sedona, Arizona
Offline sleshin
Re: Unable to Save a Project
« Reply #1 on: 2011 June 02 17:06:44 »
More info on this, I removed the ReadPSF module and project function now works properly. Re-installing ReadPSF causes the same failure to save a project with error message as above. Obviously some incompatibility of the Read PSF process. I do like to use this module to get an estimate of PSF for use with the Deconvolution process. Is there a way to fix this so will be able to install the Read PSF module and still be able to save projects?
Steve Leshin
Sedona, Arizona
