Author Topic: ACDNR interface corruption  (Read 13513 times)
Offline DarrenS
« on: 2011 June 01 13:05:15 »
Just upgraded to
1.7 for windows 32
PI-windows-x86-01.07.00.0695-nsi-20110529-c.exe
bottom of the acdnr interface is corrupting
tried an un-install and re-install same result
all other process menus appear to be ok
Darren
Re: ACDNR interface corruption
« Reply #1 on: 2011 June 01 17:08:52 »
Hi DarrenS, same version and no problem here.
Alejandro.
Offline DarrenS
« Reply #2 on: 2011 June 02 13:10:46 »
Thanks for checking Alejandro
Tried reboots and a few other things but still the same. Looks like the dark and bright sliders are trying to display in the same place.
Will try re-downloading and re-installing.
Darren
« Reply #3 on: 2011 June 02 13:17:43 »
re-downloading and re-installing is for the birds. It won't change anything. The installer checks itself for integrity before doing the install.
Occasionally these types of corruptions show up. It's like QT gets confused about font sizes or doesn't find the expected fonts and that breaks the auto layout code. Hopefully Juan has more concrete ideas how to debug this.
« Reply #4 on: 2011 June 02 14:39:23 »
A full settings reset may help. Execute PixInsight with the Ctrl key pressed, and follow instructions.
« Reply #5 on: 2011 June 02 16:01:18 »
Did you change the default font sizes in your system? If yes, this might be the problem.
Offline DarrenS
« Reply #6 on: 2011 June 04 02:25:46 »
Many thanks for the ideas
Tried the Ctrl start - reset pixin - still the same
Changed the process interface font - this has an effect on the menu, increased to 12 and the sliders disapear altogether. (screenshot) but still corrupted so no real benefits.  :(
Darren
« Reply #7 on: 2011 June 04 09:08:48 »
Hi Darren,
This is a very strange problem, haven't seen anything similar before. Let me make some tests on Windows XP to find a solution.
There is a workaround:
- Restore the default font with Preferences.
- Select: Window > GUI Style > Plastique
- Exit PixInsight.
- Launch PixInsight Core. The problem should be gone. You won't have desktop integration with the XP theme, but the Plastique GUI style is also nice and works flawlessly.
Sorry for the inconvenience; I'll try to fix this issue as soon as possible.
Offline DarrenS
« Reply #8 on: 2011 June 07 11:37:48 »
Set the gui to Plastique
unfortunately still the same :(
Darren
« Reply #9 on: 2011 June 08 07:26:45 »
Hi Darren,
Then this is really strange. The Plastique style doesn't use the system theme engine, so it should work in a predictable and bug-free way on all platforms. For some reason that I can't figure out, even Plastique is not rendering fonts correctly on your machine.
Which version of Windows are you using? Have you customized your screen preferences (in Windows, not in PixInsight) to set a nonstandard font face and/or size?
Offline DarrenS
« Reply #10 on: 2011 June 09 12:54:22 »
Juan
do not spend any time on this, it is not causing me problems. It seems to be system specific and I intend to upgrade to a 64bit platform soonish
many thanks for the software, it has improved my images leaps and bounds.
Darren
Offline RobF2
  • Rob
    • Rob's Astropics
« Reply #11 on: 2011 June 11 21:36:19 »
I'm suffering from this affliction too now I've upgraded to 1.07.00.0697.  Running Windows XP Home 32bit with 120% fonts.  I've tried returning to default fonts, different UI settings.  I can actually JUST manipulate the various sliders.
I'd just about weened myself off doing final noise tweaks in photoshop/Noise ninja too actually and made myself come to grips with ACDNRs parameters.   :-[
Not a show stopper, but something seems to have changed.
Rob's Astropics
Offline edif300
    • http://www.astrosurf.com/ilizaso
« Reply #12 on: 2011 June 22 01:30:20 »
Juan,
Same problem here, on both win xp pro 02 SP3 and win xp home edition 02 SP3
Perfect on both before updating to 1.7...
« Last Edit: 2011 June 22 01:38:13 by edif300 »
Astroargazkigintza
« Reply #13 on: 2011 June 22 03:32:14 »
Hi Iñaki et al
I'm working on fixing this bug and hope to release an update very soon. Sorry for the troubles!
Offline edif300
« Reply #14 on: 2011 June 22 06:24:16 »
Many thanks!
Astroargazkigintza
