Author Topic: Poor Image Integration  (Read 10645 times)
Offline Andres.Pozo
Re: Poor Image Integration
« Reply #15 on: 2011 June 03 01:11:30 »
I then calibrated my lights with only the Master Flat subtracted, without Dark or Bias subtraction.
I think that you can't apply the MasterFlat without having applied before at least a Bias. Also the MasterFlat itself must be Bias/Dark calibrated. The calibration is a sequence where its steps are not independent and the can not be applied isolated.
« Reply #16 on: 2011 June 03 03:58:59 »
Thats correct. Basically, you should be doing (lights-bias)/(flats-bias), and this is different from lights/flats. Simple math.... And if there is dark current, this should be considered as well.
Offline Philip de Louraille
« Reply #17 on: 2011 June 03 05:36:27 »
I used auto background extractor on the first jpg (!) and removed quite a lot of the gradient. I would think it would do a much better job from the 12- or 16-bit image still in linear mode.
Philip de Louraille
Offline Doug
« Reply #18 on: 2011 June 05 04:09:20 »
Thanks for all your comments.
I'll try out more tests and see where I get to.
Doug Ives
