Author Topic: M106  (Read 11340 times)
Re: M106
« Reply #15 on: 2011 June 13 14:51:09 »
Nice picture Harry!
Offline Jules
Re: M106
« Reply #16 on: 2011 June 13 23:44:53 »
Harry
Do you have plans to cover Atrous wavelet transform / convolution / deconvolution, your videos are really good and you have a really good way of putting across complicated subject matter.
Julian
Offline Howard
    • Cabin in the Sky Observatory
Re: M106
« Reply #17 on: 2011 June 14 04:52:34 »
Hi Harry:
Your videos also got me off to the races. Bite sized, crystal clear, and covering alot of ground, they bust through the PixInsight learning barrier :). Many thanks for that!
The colors in the M106 image are gorgeous.
Best regards,
Howard.
Obsessed with the photographic experience of the cosmos!
Cabin in the Sky Observatory: PlaneWave CDK17, Paramount ME, Apogee U16M, Astrodon filters & MOAG, Starlight Lodestar, in a roll-off roof under the deep, dark skies of rural BC Canada.
Offline Harry page
Re: M106
« Reply #18 on: 2011 June 14 09:58:46 »
Hi Gents
Thanks for the comments always very welcome  :laugh:
There is always more video's required  ;D and will try and do some more  8)  of course I am waiting for Juan to do some more  >:D
Has any body had success with the " vicent way " yet
Regards Harry
Harry Page
Offline sleshin
Re: M106
« Reply #19 on: 2011 June 14 16:50:08 »
Hi Harry,
As always, your fine tutorials are very much appreciated. On this one, I wanted to look at Vicent's description of this method. Can you tell me where to find it. I have seen his tutorial on the PI site but that is really quite general and specific formulas are not included.
Steve Leshin
Stargazer Observatory
Sedona, Arizona
Offline Harry page
Re: M106
« Reply #20 on: 2011 June 15 14:20:11 »
We did not get a full description and had to get the info straight from the horses mouth  :D
here was a bit of info he did release http://pixinsight.com/forum/index.php?topic=1982.0
Regards Harry
Harry Page
Offline sleshin
Re: M106
« Reply #21 on: 2011 June 15 17:19:08 »
Thanks Harry.
BTW, I have tried the method as described in your tutorial and it works beautifully. Galaxy and star color preserved with Ha areas enhanced. Appears that the amount of enhancement is controlled by the multiplication factor in formula #2.
I did look at the thread you just referenced and noted that Vicent was perhaps 1 or 2 paragraphs short of completing what would have been good documentation of this method. I really appreciate that you took the time to complete the job, and rather elegantly I might add.
Steve Leshin
Sedona, Arizona
Offline Harry page
Re: M106
« Reply #22 on: 2011 June 16 10:11:40 »
Hi Steve
I am glad you found it worked well I was very pleased the method  :)
As you say the enhancement is controlled by multiplication factor in formula 2 and is of course subject to the quality of your Ha  ;D
I am looking forward to getting some more data so I can play more with this method  8)
Regards Harry
Harry Page
Offline Gian Corrado
Re: M106
« Reply #23 on: 2011 June 19 10:25:52 »
Hi Harry,
Very nice picture !!!
Thank you for the tutorials videos...so useful for a novice as me... :)
Gian
Offline Lex
  • We do it at night...
Re: M106
« Reply #24 on: 2011 July 02 18:54:19 »
Harry,
That's a gorgeous picture again and I can assure you that I can't do it better  ::)
Best
Lex
Clear Skies!!
Lex
Offline Howard
Re: M106
« Reply #25 on: 2011 August 06 14:49:57 »
Hi Harry:
I've been processing LRGBHa exposures of the Bubble Nebula following your very clear workflow for Vicent's technique of blending the Ha into the R, whilst minimizing the added noise from the Ha.
I wonder if I goofed in retrospect to shoot the Ha frames binned 2x2 (and likewise for the RGB), with the L unbinned? I thought to copy the usual procedure of upsampling the "colour" channels into the higher resolution L. However, there is so much rich texture in the Ha, which does not appear to have been adequately captured in the unbinned L (though I'm a bit mystified as to why that should be, since the L ought to capture everything - maybe I've not adequately processed the L?).
Any suggestions for how best to adapt the workflow to LRGBHa, rather than RGBHa?
I'd also appreciate to hear any comments on whether to reshoot the Ha unbinned, and what might be the best relative exposure times and resolutions in Ha and R.
Many thanks,
Howard.
