Author Topic: FITSKeyword sequential utility  (Read 19112 times)
Offline NKV
Re: FITSKeyword sequential utility
« Reply #15 on: 2012 January 25 18:28:49 »
when I try to download the script I get an "error of compilation sript" ... in the first line it seems
I think it's Internet Browser problem. Be sure that you get FITSkey_0.05.js
Sometimes i getting .php file instead real attachment.
Any way FITSkey_0.06.js code below. You can copy the code to PI script editor and run.
#feature-id    Utilities > FITS Keywords
#define VERSION   0.06
#include <pjsr/DataType.jsh>
#include <pjsr/Sizer.jsh>
//#include <pjsr/FrameStyle.jsh>
#include <pjsr/TextAlign.jsh>
#define DEBUGGING_MODE_ON false
function copyFile( sourceFilePath, targetFilePath )
   var f = new File;
   f.openForReading( sourceFilePath );
   var buffer = f.read( DataType_ByteArray, f.size );
   f.close();
   f.createForWriting( targetFilePath );
   f.write( buffer );
   //f.flush(); // optional; remove if immediate writing is not required
   f.close();
function trim( s )
   return s.replace( /^\s*|\s*$/g, '' );
function LoadFITSKeywords( fitsFilePath )
   function searchCommentSeparator( b )
      var inString = false;
      for ( var i = 9; i < 80; ++i )
         switch ( b.at( i ) )
         case 39: // single quote
            inString ^= true;
            break;
         case 47: // slash
            if ( !inString )
               return i;
            break;
      return -1;
   var f = new File;
   f.openForReading( fitsFilePath );
   var keywords = new Array;
   for ( ;; )
      var rawData = f.read( DataType_ByteArray, 80 );
      var name = rawData.toString( 0, 8 );
      if ( name.toUpperCase() == "END     " ) // end of HDU keyword list?
         break;
      if ( f.isEOF )
         throw new Error( "Unexpected end of file: " + fitsFilePath );
      var value;
      var comment;
      if ( rawData.at( 8 ) == 61 ) // value separator (an equal sign at byte 8) present?
         // This is a valued keyword
         var cmtPos = searchCommentSeparator( rawData ); // find comment separator slash
         if ( cmtPos < 0 ) // no comment separator?
            cmtPos = 80;
         value = rawData.toString( 9, cmtPos-9 ); // value substring
         if ( cmtPos < 80 )
            comment = rawData.toString( cmtPos+1, 80-cmtPos-1 ); // comment substring
         else
            comment = new String;
      else
         // No value in this keyword
         value = new String;
         comment = rawData.toString( 8, 80-8 );
      // Perform a naive sanity check: a valid FITS file must begin with a SIMPLE=T keyword.
      if ( keywords.length == 0 )
         if ( name != "SIMPLE  " && trim( value ) != 'T' )
            throw new Error( "File does not seem a valid FITS file: " + fitsFilePath );
      // Add new keyword. Note: use FITSKeyword with PI >= 1.6.1
      keywords.push( new FITSKeyword( name.toString(), value.toString(), comment.toString() ) );
   f.close();
   return keywords;
function MyDialog()
   this.__base__ = Dialog;
   this.__base__();
   this.inputFiles = new Array(); //Array of filename with full path
   this.inputKeys = new Array();  //keys of all files. Big RAW array of all file keys.
   this.keyTable = new Array();   //accumulated names of keywords from all files
   this.keyEnabled = new Array(); //true == selected keywords
   this.defaultKey = new Array("SET-TEMP","EXPOSURE","IMAGETYP");
   var outputDirectory = "";
   this.engine_mode = 0;       //0=move, 1=copy
   if (DEBUGGING_MODE_ON) var outputDirectory = "D:/temp";
   this.onShow = function()
//      this.filesAdd_Button.onClick();
   //hide columns of unchecked keywords---------------------------
   this.hideKey = function ()
      //if (DEBUGGING_MODE_ON) console.clear();
      for (var i in this.keyEnabled)
         c = parseInt(i) + 1;
            console.write("Column: " + c + " enabled: " + this.keyEnabled[i] + " " );
         this.files_TreeBox.showColumn( c, this.keyEnabled[i]);
   // KeyWord Dialog
   this.SD = new KeyDialog( this );
   this.Key_button = new ToolButton( this );
   with ( this.Key_button )
      icon = new Bitmap( ":/images/icons/text.png" );
      toolTip = "KeyWord Dialog";
      onClick = function()
         if (this.dialog.keyTable.length)
            this.dialog.SD.execute();
            this.dialog.hideKey();
   // File List TreeBox
   this.files_TreeBox = new TreeBox( this );
   with ( this.files_TreeBox )
      rootDecoration = false;
      numberOfColumns = 1;
      multipleSelection = true;
      headerVisible = true;
      headerSorting = true;
      setHeaderText(0, "Filename");
      onNodeUpdated = function( node, column ) // Invert CheckMark
         for (var i=0; i < this.selectedNodes.length; i++)
            if ( node == this.selectedNodes[i] ) continue; // skip curent clicked node, because it will inverted automaticaly
            this.selectedNodes[i].checked = !this.selectedNodes[i].checked;
   this.UpdateTreeBox = function ()
      this.files_TreeBox.clear();
      this.keyTable = new Array(); // clear
      // Accumulate all KeyNane in keyTabe
      for ( var i in this.inputFiles)
         var key = this.inputKeys[i]; // keywords of one file
         var node = new TreeBoxNode( this.files_TreeBox );
         node.setText( 0, this.inputFiles[i] ); //write name to first coummn
         node.checked = true;
         for ( var j in key )
            var name = key[j].name; //name of Keyword from file
            var k = this.keyTable.indexOf(name);// find index of "name" in keyTable
            if (k < 0) // new keyName
               this.keyTable.push(name);//add keyword name to table
               this.files_TreeBox.numberOfColumns++;// add new column
               this.files_TreeBox.setHeaderText(this.keyTable.length, name);//set name of new column
               k = this.keyTable.length-1;
               this.keyEnabled[k] = (this.defaultKey.indexOf(name)> -1);//compare with defauld enabled keywords
            if (key[j].isNumeric) node.setText( k+1, Number(key[j].value).toFixed(3) );
            else node.setText( k+1, key[j].value );
      this.hideKey(); //hide columns of unchecked keywords
   this.getFiles = function (fileNames)
         console.writeln("Found "+fileNames.length);
         console.write("Checked:.");
         //for ( var b=0; b<fileNames.length.toString().length; b++)
         //   console.write(".");
      var qtyNew = 0;
      for ( var i in fileNames )
            for ( var b=0; b<i.toString().length; b++)
               console.write("\b");
            console.write(parseInt(i)+1); processEvents();
         if (this.inputFiles.indexOf(fileNames[i]) < 0) //Add file only one times
            var key = LoadFITSKeywords(fileNames[i]);
            this.inputFiles.push(fileNames[i]);
            this.inputKeys.push(key);
            qtyNew++;
      console.writeln(" ");
      if (qtyNew == 0) {console.writeln("No new files"); return;}
      if (DEBUGGING_MODE_ON) {console.writeln("New ",qtyNew,"\nTotal ",this.inputFiles.length); processEvents();}
      this.UpdateTreeBox();
      this.QTY.text = "Total files: " + this.inputFiles.length;
      this.setMinWidth(800);
      this.adjustToContents();
      this.dialog.update();
   // Total file Label ---------------------------------------------------------------------------
   this.QTY = new Label( this );
   this.QTY.textAlignment = TextAlign_Right|TextAlign_VertCenter;
   //enable/disable buttons
   this.update = function()
      var enabled = !((!this.inputFiles.length) || (!outputDirectory));
      this.dialog.move_Button.enabled = enabled;
      this.dialog.copy_Button.enabled = enabled;
      this.dialog.txt_Button.enabled = enabled;
   // Add files ---------------------------------------------------------------------------
   this.filesAdd_Button = new ToolButton( this );
   with ( this.filesAdd_Button )
      icon = new Bitmap( ":/images/image_container/add_files.png" );
      toolTip = "Add files";
         var ofd = new OpenFileDialog;
         ofd.multipleSelections = true;
         ofd.caption = "Select FITS Files";
         ofd.filters = [["FITS Files", "*.fit", "*.fits", "*.fts"]];
         if ( ofd.execute() ) this.dialog.getFiles(ofd.fileNames);
   // Add Dir ---------------------------------------------------------------------------
   this.dirAdd_Button = new ToolButton( this );
   with ( this.dirAdd_Button )
      icon = new Bitmap( ":/images/icons/folders.png" );
      toolTip = "Add folder including subfolders";
         var gdd = new GetDirectoryDialog;
         //gdd.initialPath = outputDirectory;
         gdd.caption = "Select Input Directory";
         if ( gdd.execute() )
            if (DEBUGGING_MODE_ON) {console.writeln("Start serching FITS file in SubFolders"); processEvents();}
            var fileNames = searchDirectory(gdd.directory+"/*.fit" ,true)
            .concat(searchDirectory(gdd.directory+"/*.fits",true))
            .concat(searchDirectory(gdd.directory+"/*.fts",true));
            if (DEBUGGING_MODE_ON) {console.writeln("Finish serching FITS file in SubFolders"); processEvents();}
            this.dialog.getFiles(fileNames);
   // Close selected files ---------------------------------------------------------------------------
   this.files_close_Button = new ToolButton( this );
   with ( this.files_close_Button )
      icon = new Bitmap( ":/images/close.png" );
      toolTip = "<p>Close selected images.</p>";
         if ( this.dialog.inputFiles.length == 0 ) return;
         for ( var i = this.dialog.files_TreeBox.numberOfChildren; --i >= 0; )
            if ( this.dialog.files_TreeBox.child( i ).selected )
               this.dialog.inputFiles.splice(i,1);
               this.dialog.inputKeys.splice(i,1);
               this.dialog.files_TreeBox.remove( i );
         this.dialog.QTY.text = "Total files: " + this.dialog.inputFiles.length;
   //Output Dir --------------------------------------------------------------------------------------
   this.outputDir_Edit = new Edit( this );
   this.outputDir_Edit.readOnly = true;
   this.outputDir_Edit.text = outputDirectory;
   this.outputDir_Edit.toolTip ="select output directory.";
   this.outputDirSelect_Button = new ToolButton( this );
   with ( this.outputDirSelect_Button )
      icon = new Bitmap( ":/images/icons/select.png" );
      toolTip = "Select output directory";
         gdd.caption = "Select Output Directory";
            outputDirectory = gdd.directory;
            this.dialog.outputDir_Edit.text = outputDirectory;
   //engine----------------------------------------------------------------------------
   this.apply = function ()
      var targetFiles = new Array();
         targetFiles[i] = outputDirectory;
      for ( var i in this.keyTable) // in all possible keywords
         if (!this.keyEnabled[i]) continue; // ignore disabled keywords
         var name = this.keyTable[i]; // keyword name
         for ( var j in this.inputFiles) // for in all files
            var key = this.inputKeys[j]; // key = all keywords from curent file
            for (var k in key) // for in all keywords of the file
               if (!(key[k].name == name)) continue; // skip not equal keyword name
               // keyword found in the file >> extract value
               if (key[k].isNumeric)
                  var value = parseFloat(key[k].value)
               else
                  var value = key[k].value;
                  value = value.replace( /'/g, "" );
                  value = value.replace( / /g, "" ); // delete left space
                  value = value.replace( /:/g, "." );
               // use keyword value to make subDir name
               targetFiles[j] = targetFiles[j] + "/" + value;
               break; // next file
      for ( var i = 0; i < this.files_TreeBox.numberOfColumns; i++ )
         var name = this.files_TreeBox.headerText( i ); // extract keyword name from header files_TreeBox
         if ( name == "Filename" ) continue; // skip Filename column
         if ( !this.files_TreeBox.isColumnVisible( i ) ) continue; // skip hiden column
         if (DEBUGGING_MODE_ON) console.writeln("Column name: " + name );
               else
               break; // next file
      var skip = 0;
      for ( var i in targetFiles)
         if ( !this.files_TreeBox.child(parseInt(i)).checked ) { skip++; continue; }
         var fileDir = targetFiles[i];
         if (DEBUGGING_MODE_ON) console.writeln("Create fileDir: " + fileDir );
         if (!File.directoryExists(fileDir)) File.createDirectory(fileDir);
         var s = this.inputFiles[i];
         var t = fileDir+"/"+File.extractName(s)+File.extractExtension(s);
         if ( File.exists( t ) )
            for ( var u = 1; ; ++u )
               var tryFilePath = File.appendToName( t, '_' + u.toString() );
               if ( !File.exists( tryFilePath ) ) { t = tryFilePath; break; }
         if (this.engine_mode==0)
            console.writeln("move ", s," to ",t);
            File.move(s,t);
         else
            console.writeln("copy ", s," to ",t);
            copyFile(s,t);
         processEvents();
      console.writeln("Total files: ", targetFiles.length,"; Skiped: ",skip,"; Processed: ",targetFiles.length-skip);
   //Engine buttons --------------------------------------------------------------------------------------
   this.move_Button = new PushButton( this );
   with ( this.move_Button )
      text = "Move";
      toolTip = "Move Checked files to output directory";
      enabled = false;
         parent.apply();
         this.dialog.ok();
   this.copy_Button = new PushButton( this );
   with ( this.copy_Button )
      text = "Copy";
      toolTip = "Copy Checked files to output directory";
      enabled = false;
         parent.engine_mode = 1;
         parent.apply();
   this.txt_Button = new PushButton( this );
   with ( this.txt_Button )
      text = "FITS.txt";
      toolTip = "For Checked files wtrite FitKeywords value to file FITS.txt in output directory";
      enabled = false;
         var tab = String.fromCharCode(9);
         var f = new File();
         var fileName = "FITS_keys";
         var fileDir = outputDirectory;
         var t = fileDir + "/" + fileName + ".txt";
               for( var n = u.toString(); n.length < 4 ; n = "0" + n);
               var tryFilePath = File.appendToName( t, '-' + n );
         f.create(t);
         for ( var i in parent.keyTable)//output header
            if (!parent.keyEnabled[i]) continue;
            f.outTextLn(parent.keyTable[i]+tab);
         f.outTextLn("Filename"+String.fromCharCode(10,13));
         var skip = 0;
         for ( var j in parent.inputFiles)//output FITS data
            if ( !parent.files_TreeBox.child(parseInt(j)).checked ) { skip++; continue; }
            var key = parent.inputKeys[j];
               var name = parent.keyTable[i];
               for (var k in key)
                  else
                     value = value.replace( / /g, "" ); //delete left space
                  f.outText(value.toString());
                  for (var w = value.toString().length; w < 8; w++) f.outText(" ");
                  f.outText(tab);
                  k=-1;
                  break;
               if (k > -1) f.outText("        "+tab);
            f.outTextLn(parent.inputFiles[j]+String.fromCharCode(10,13));
         f.close();
         console.writeln("FITSKeywords saved to ",t);
   //Sizer------------------------------------------------------------
   this.fileButonSizer = new HorizontalSizer;
   with ( this.fileButonSizer )
      margin = 6;
      spacing = 4;
      add( this.Key_button );
      add( this.filesAdd_Button );
      add( this.dirAdd_Button );
      add( this.files_close_Button );
      add( this.QTY );
      addStretch();
   this.inputFiles_GroupBox = new GroupBox( this );
   with (this.inputFiles_GroupBox)
      title = "Input";
      sizer = new VerticalSizer;
      sizer.margin = 6;
      sizer.spacing = 4;
      sizer.add( this.files_TreeBox,100 );
      sizer.add( this.fileButonSizer );
   this.outputDir_GroupBox = new GroupBox( this );
   with (this.outputDir_GroupBox)
      title = "Output";
      sizer = new HorizontalSizer;
      sizer.margin = 6;
      sizer.spacing = 4;
      sizer.add( this.outputDir_Edit, 100 );
      sizer.add( this.outputDirSelect_Button );
   this.sizer2 = new HorizontalSizer;
   with ( this.sizer2 )
      spacing = 2;
      add( this.move_Button);
      add( this.copy_Button);
      add( this.txt_Button);
      addStretch();
   this.sizer = new VerticalSizer;
   with ( this.sizer )
      margin = 2;
      spacing = 2;
      add( this.inputFiles_GroupBox );
      add( this.outputDir_GroupBox );
      add( this.sizer2 );
   //this.move(50,100); // move dialog to up-left corner
//End if Main Dialog------------------------------------------------------------
//Second Dialog------------------------------------------------------------
function KeyDialog( pd ) //pd - parentDialog
   this.__base__();
   this.windowTitle = "Select KeyWords";
      var p = new Point( pd.position );
      p.moveBy( 16,16 );
      this.position = p;
      this.keyword_TreeBox.clear();
      for (i in pd.keyTable)
         var node = new TreeBoxNode(this.keyword_TreeBox);
         node.setText( 0, pd.keyTable[i] );
         node.checked = pd.keyEnabled[i];
      this.file_ComboBox.clear();
      for (i in pd.inputFiles)
         this.file_ComboBox.addItem(pd.inputFiles[i]);
      this.file_ComboBox.onItemSelected(0);
      this.setMinSize(400,600);
   this.onHide = function()
      for (var i in pd.keyTable)
         checked = this.keyword_TreeBox.child( parseInt(i) ).checked;
            console.write("Key#: " + parseInt(i) + " checked: " + checked );
         pd.keyEnabled[i] = checked;
      pd.setMinWidth(800);
   this.file_ComboBox = new ComboBox( this );
   with ( this.file_ComboBox )
      onItemSelected = function( index )
         for ( var i in pd.keyTable)
            parent.keyword_TreeBox.child(parseInt(i)).setText(1,pd.files_TreeBox.child(index).text(parseInt(i)+1));
   // FITS keyword List TreeBox
   this.keyword_TreeBox = new TreeBox( this );
   with ( this.keyword_TreeBox )
      toolTip = "Checkmark to include to report";
      numberOfColumns = 2;
      setHeaderText(0, "name");
      setHeaderText(1, "value");
      setColumnWidth(0,100);
      setColumnWidth(1,200);
   this.sizer.margin = 4;
   this.sizer.spacing = 4;
   this.sizer.add( this.file_ComboBox );
   this.sizer.add( this.keyword_TreeBox );
MyDialog.prototype = new Dialog;
KeyDialog.prototype = new Dialog;
var dialog = new MyDialog;
dialog.execute();
« Last Edit: 2012 January 26 00:41:03 by NKV »
Offline NKV
« Reply #16 on: 2012 January 25 18:38:45 »
No files appear in the list box after selection.
Max, look at line #9 in the script:
#define DEBUGGING_MODE_ON false(Note: fast way to open PI ScriptEditor is Ctrl+Alt+E)
Change "false" to "true" and press F9. You will see many information in Console. I hope it's can help to find the bug.
Nikolay
Offline NKV
« Reply #17 on: 2012 January 26 00:43:07 »
Ver 0.06
+Sorting
+more toolTip
Bag fix of Check-mark invert.
Offline Fco. Bosch
« Reply #18 on: 2012 January 26 09:16:39 »
Thanks Nicolay! Here is all the information that we can't get when we open files with Windows. The *.fit files are nearly unknow for this OS, and we open frecuently files that we don't want and conversely, because we don't know the due properties of the files.
I want to ask you if is possible to go further with the script and to make it like an "open files" menu  >:D
Fco. Bosch
Offline NKV
« Reply #19 on: 2012 January 26 19:53:42 »
Sorry, what are you mean?
Offline Fco. Bosch
« Reply #20 on: 2012 January 27 08:40:18 »
I'm sorry; what I intend to say is that would be interesting if we can browse our files with the data of your script, and have the facility of open it in PI (like an "open file" menu); so would be possible to select the apropiate files for our work, due to the information that the script provides. Now I select and open my files blindly, without to know their time exposure, filter, binning ..., because these data are unknow for the explorer window of Window(that provides the "open file" function).
Thanks!
Fco. Bosch
Offline NKV
« Reply #21 on: 2012 January 28 07:17:10 »
You need file browser with FitsKeyWords support? Right?
It's good idea, but which FitsKeyWords you want to add to browser? (Size,bin,exposure,filter,..)  How many KeyWords?
Anyway it's other story for wish list  http://pixinsight.com/forum/index.php?board=9.0
I try to write script which help to sorting (move or rename) files after long session. Light to "Light" folder, Dark to "Dark" folder... etc.
Welcome if you have any idea.
Offline Fco. Bosch
« Reply #22 on: 2012 January 29 14:51:16 »
Yes, I think that are interesting the important data  for any processing task, like date, time, object, timeExp, ImageTyp, Filter, temp, Binning, ... If we can know these properties we can decide better what files are interesting in each case. In any case, Thanks!!
Fco. Bosch
« Reply #23 on: 2012 January 30 00:57:21 »
Maybe this is what you need http://astroshed.com/software.html. Not exactly cheap, but...
Offline mmirot
« Reply #24 on: 2012 March 02 10:23:40 »
Cool app,
I got it to work fine. Probable user error before. :surprised:
It is great to have utilily the allows image sorting based on the fits headers.
Anything you add to it would be great.
Thought for features.
Search by keyword and give results as a report rather than moving files only.
See contents of sub directories too.
Flexibilty on how to sort files in to folders... ie choose folder hierarchy bases on the FITs Keys.
Abilty to delete files of folders directly.
Count files
Total exposure time for each each type BIN, FILTER etc.
Data base management a file manipulations are such a headache  :'(
Tools like this really help
This one helped me a lot already.
Max
