Author Topic: FITSKeyword sequential utility  (Read 19119 times)
Offline NKV
« on: 2011 April 19 05:10:09 »
In attachment script for build sequential FITS utility. For example: extract "CCD-TEMP" from FITS Header and write it to filename. Or create subdirectories according FITSKeyword.value and put files with similar value to good place for it.
Now it's just skeleton. Script accumulate all FITS Header keyword for all file and show it on the screen. But if you have any idea, welcome!
Just say what you want to see in next version.
Best regards,
Nikolay.
PS FITS engine it stole. Juan thanks and sorry for.
« Last Edit: 2012 January 26 00:40:04 by NKV »
Offline NKV
Re: FITSKeyword sequential utility
« Reply #1 on: 2011 April 20 09:57:09 »
Ver.0.02
+move files to subdir according selected FITS KeyWords.
« Last Edit: 2011 May 30 02:06:30 by NKV »
Hans Pleijsier
  • Guest
« Reply #2 on: 2011 April 20 13:04:38 »
Thank you, Nikolay.
Looks interesting.
I will take a look and report back later.
HP
Hans Pleijsier
  • Guest
« Reply #3 on: 2011 April 20 13:14:58 »
first impression: this script works fine on a Mac.
Offline NKV
« Reply #4 on: 2011 April 21 03:51:03 »
Ver 0.03
+Button: Collect all files from sub folders.
+Button: Close selected files.
+DoubleClick: Invert "Checkmark" of selected files.
Offline vetenskapsman
    • Cilice Astophotography
« Reply #5 on: 2011 May 27 20:25:51 »
Thanks Nikolay,  just what I have been looking for to get a text output of selected FITS keyword entries.
much appreciated,  -carl
Offline NKV
« Reply #6 on: 2011 May 29 07:46:00 »
Done
Ver 0.04
+button: Copy
+button: Generate text file of selected keywords
Best regards,
Nikolay.
« Last Edit: 2011 May 30 00:36:45 by NKV »
Offline NKV
« Reply #7 on: 2012 January 22 03:09:10 »
Ver 0.05 Bug fix.
Hello All!
I am try to add keyword sorting to the script. I need it to manage sub folder creation procedure.
As you can see, possible to sort ThreeBox Header ( Use mouse push-move-drop to change column position in GUI ). But, i not understand how to get by JavaScript the result of GUI ThreeBox manipulation.
I mean: TreeBox.headerText( column ) ignore GUI manipulation. How to get real on screen GUI condition? Real column position?
Best regards,
Nikolay.
« Last Edit: 2012 January 26 19:55:38 by NKV »
Offline mmirot
« Reply #8 on: 2012 January 22 18:38:03 »
I see only ver 05
I can add a file or folder on a Windows 64
Max
Offline NKV
« Reply #9 on: 2012 January 25 01:30:41 »
Why not?
Offline mmirot
« Reply #10 on: 2012 January 25 08:15:34 »
Sorry,
I messed up that post.
I can not select any files or folders.
The script starts but won't doing anything from there on.
I tried the last version posted.
It is Window 7 64 system.
Max
Offline NKV
« Reply #11 on: 2012 January 25 08:36:12 »
Strange...
I have no problem. See PrintScreen.
Offline mmirot
« Reply #12 on: 2012 January 25 10:53:12 »
I should just be able to add file with the + icon. I will reboot and try again when I get home.
Max
Offline Fco. Bosch
« Reply #13 on: 2012 January 25 10:56:34 »
when I try to download the script I get an "error of compilation sript" ... in the first line it seems
Fco. Bosch
Offline mmirot
« Reply #14 on: 2012 January 25 16:10:19 »
I checked again on another windows 64 cpu.
No files appear in the list box after selection.
Max
