Author Topic: How to save multiple imgfes at once?  (Read 3181 times)
Offline bitli
« on: 2011 April 17 04:14:13 »
Hello,
I have a set of images in an ImageContainer (20 or so) and I would like to save these images to files. Is there a way to save all images together (there does not seem to be a 'save' process I could drag the ImageContainer to)?
-- bitli
Re: How to save multiple imgfes at once?
« Reply #1 on: 2011 April 17 07:16:17 »
Hola Bitli,
No entiendo muy bien que es lo que tenes que hacer, pero podrías escribir una extensión en "Output template", seleccionar un "Output directory" si lo tenes que guardar en un lugar distinto al origen y luego arrastrar el ImageContainer y tirar sobre él cualquier proceso que no le haga nada, como las curvas en este caso.
Saludos. Alejandro.
Hi Bitli,
I do not understand very well that you need to do, but you might write an extension in " Output control ", to select a " Output directory " if you need to save it in a place different from the original and then drag the ImageContainer and throw on it any process that does not do anything, as curves in this case.
Regards, Alejandro.
Offline bitli
« Reply #2 on: 2011 April 21 13:42:22 »
Thanks for the proposal, but this did not work, the "transformation" is done in place (the images do not have a file name, I just added them from the workspace to the image container).
-- bitli
