Author Topic: Med() function question  (Read 3535 times)
Offline StasV
« on: 2011 March 28 22:06:59 »
As I understand, med() function is able to work with a single image only.
Is it possible in PixelMath to calculate a median value of the sum of two images?
FSQ106ED, ASA DDM60 mount, STL11k,  HomeDome HD6
Remote control observatory, San Pedro De Atacama, Chile. In collaboration with Yuri Beletsky
Re: Med() function question
« Reply #1 on: 2011 March 29 02:08:51 »
PixelMath is a pixel-by-pixel process. The med(image) function returns the median of the specified image ($T by default), which remains invariant during PixelMath execution.
To compute the median of the sum of two or more images you need a script. Such a script is rather easy to write though:
#include <pjsr/ImageOp.jsh>
#include <pjsr/StdButton.jsh>
function MedianOfTwoAdded( img1, img2 )
   var imgs = new Image;
   imgs.assign( img1 );
   imgs.apply( img2, ImageOp_Add );
   var m = imgs.median();
   imgs.free();
   return m;
function main()
   var vA = View.viewById( "A" );
   var vB = View.viewById( "B" );
   if ( vA.isNull || vB.isNull )
      (new MessageBox( "Source image(s) not available.",
                       TITLE, StdIcon_Error, StdButton_Ok )).execute();
      return;
   console.writeln( format( "%.6f\n", MedianOfTwoAdded( vA.image, vB.image ) ) );
   console.show();
main();
Just replace "A" and "B" with the identifiers of your images (or rename your images to "A" and "B"), and run the script. If more than a few images are required, the above script is easily generalizable to image lists of arbitrary length using arrays.
« Reply #2 on: 2011 March 29 08:33:36 »
Suggestion: you may expand PM by enabling calcularions inside functions ;) then, it may be possible to run Med(A+B)
Offline vicent_peris
    • http://www.astrofoto.es/
« Reply #3 on: 2011 March 29 12:40:00 »
Or release a Calculator.
V.
« Reply #4 on: 2011 March 29 14:13:28 »
Pixel Math? :D
