Author Topic: LinearPatternGeneration Script  (Read 5668 times)
Offline Enzo De Bernardini
  • Resistance is futile.
    • Astronomí­a Sur
« on: 2011 March 22 12:46:40 »
I wish to introduce a simple script designed to generate linear patterns, inspired by a problem that showed Alejandro Tombolini some time ago. Its operation is simple: you enter the comma separated values in the fields R, G and B in the (preferred) range 0.0-1.0 and the script generates the linear pattern (either vertical or horizontal) that can then be subtracted from the image. You can create an instance icon too. GUI screenshot and script attached.
Later, Alejandro will show us a practical case where the subtraction of the pattern was successfully implemented using PixelMath.
Best regards,
Enzo.
« Last Edit: 2011 March 22 14:32:11 by Enzo De Bernardini »
