Author Topic: Unable to delete samples in DBE Tool (Mac Version)  (Read 9360 times)
Offline Lex
  • We do it at night...
« on: 2011 March 10 04:36:16 »
Hello,
after generating samples in DBE tool I am unable to delete Samples situated in non useful zones...
There is no delete key on Macs, I know, but where is the clue?  :)
For the rest, thanks guys for that genius piece of the art called Pixinsight!
Great Job!!!
Lex
Clear Skies!!
Lex
Re: Unable to delete samples in DBE Tool (Mac Version)
« Reply #1 on: 2011 March 10 15:34:47 »
you should be able to highlight the sample you want to get rid of and press the backspace key. you have to take care when clicking on a sample to get right on top of it, or you'll create a new one and then delete the new one.
IMHO you might as well place all the samples by hand; you'll get a better result. but autogenerating and deleting samples that are over foreground features works too, i guess.
Offline RBA
    • DeepSkyColors
« Reply #2 on: 2011 March 10 18:49:01 »
Even so, and without getting into what is better (each case is different and starting with an autogenerated set actually is not a bad strategy sometimes) you may find you have to go back and move or delete a given sample to refine your background model. It happens to me hundreds of times :)
« Reply #3 on: 2011 March 10 22:46:52 »
...after generating samples in DBE tool I am unable to delete Samples situated in non useful zones...
Simply select a sample (with mouse or by navigating using the arrow icons in the DBE GUI), then use the red x in the GUI (top right region).
Offline Lex
« Reply #4 on: 2011 March 11 00:18:14 »
Hy,
Okay, thanks a lot friends; I'll try this ASAP, but I think that the issue with the backspace doesn't work on my setup, as strange as it can sound???
The Application even forgets the page-layout sometimes and I then have to reconfigure the toolbars?
By the way the Soft stays still the best  ;D
So then
Thx
Lex
Clear Skies!!
Lex
Offline Redshift
« Reply #5 on: 2011 March 11 01:04:21 »
Yes, the backspace on my Mac doesn't delete them
Dave
Offline Lex
« Reply #6 on: 2011 March 11 14:48:16 »
In fact,
it really doesn't work to delete samples with the backspace, the issue with the red X in DBE UI works but there should be an easier way to complete this task on Macs, shouldn't ?
Something like selecting several samples an be able to delete a group?
Perhaps I have overseen something?
Lex
Clear Skies!!
Lex
« Reply #7 on: 2011 March 11 21:10:03 »
you guys are right... i have a sun type 6 USB keyboard (which is the One True Keyboard) on my mac. it has a delete key over above the arrow keys and pressing that does delete a sample. i guess i never realized i was not pressing backspace.
if you have an apple keyboard that has a "function" modifier key you can press function-backspace and that should delete your samples. i just tried this on my macbook pro and it worked...
Offline Lex
« Reply #8 on: 2011 March 12 00:14:30 »
Ok,
Just to confirm my interpretation, pushing Fn+Backspace should do the Job; am I right with this?
Would be cool, because I really often need to delete generated sample :)
Lex
Clear Skies!!
Lex
« Reply #9 on: 2011 March 12 09:30:39 »
Ok,
Lex
yes that worked for me, at least.
Offline Redshift
« Reply #10 on: 2011 March 12 21:45:37 »
Ok,
Lex
Yes, it also worked for me. Thanks for that.
Dave
Offline Lex
« Reply #11 on: 2011 March 13 09:00:23 »
I'll check it out as soon as the Kids are at sleep  ::)
Regards
Lex
Clear Skies!!
Lex
Offline Lex
« Reply #12 on: 2011 March 17 13:33:28 »
Hy everyone,
this keyboard shortcut effectively works!
Thanks all!
Regards
Lex
Clear Skies!!
Lex
« Reply #13 on: 2011 March 17 15:21:48 »
still it might be nice if juan mapped the backspace key to the delete function on OSX. it's a pain in the butt having to press a key sequence, especially when your other hand is on the mouse.
Offline Lex
« Reply #14 on: 2011 March 17 23:02:34 »
Pfile,
Hy, yes in deed You are right that it would be much easier to deal with ;)
Lex
Clear Skies!!
Lex
