Author Topic: Preprocess Pipeline v0.9.0Beta  (Read 69519 times)
Offline mmirot
Re: Preprocess Pipeline v0.9.0Beta
« Reply #105 on: 2011 May 04 13:51:38 »
John has been to quiet lately. I hope he comes back online soon.
Max
Offline mmirot
« Reply #106 on: 2011 May 05 05:41:05 »
Juan,
You might want to read my recent suggestions above.
Max
Offline mmirot
« Reply #107 on: 2011 July 30 09:19:22 »
Too bad development has stopped on this.
Juan were'nt you going to pick up development on this after 1.7 release ?
Max
Offline Lex
  • We do it at night...
« Reply #108 on: 2011 October 18 04:53:29 »
Great script! No other problems than those already posted..
Nice Work
Cheers
Lex
Clear Skies!!
Lex
Offline mmirot
« Reply #109 on: 2011 October 18 09:31:28 »
It is a good script but could use a bit of polish. Interest on it has disappeared  :'(
Max
« Reply #110 on: 2011 October 18 09:46:24 »
I always had the hope it would reach "product" status. Maybe some time.
Offline RobF2
  • Rob
    • Rob's Astropics
« Reply #111 on: 2011 October 19 03:00:59 »
One of the things that really bugs me is if the script fails or I want to tweak a parameter, I lose all the settings I'd set up.  Mind you, I run the script from a pre-saved process icon on the desktop.  If I recall correctly though I should be able to re-run it (not from my desktop icon) and it will recall the most recently used settings?  Can anyone confirm that?
It really seems to be worth doing all the pre-processing in PI, but the time to do it well is still depressing unfortunately  :'(
Rob's Astropics
« Reply #112 on: 2011 October 19 03:34:43 »
Not at all. I have introduced changes and new features in version 1.7.0 precisely to facilitate writing scripts like this one (read-only process properties). However these features are still incomplete; that's why I haven't described them publicly yet.
This script is a wonderful piece of software. When it works as expected, it will make the preprocessing task much easier in PixInsight but without losing a bit of its power and flexibility. I plan on continuing development of this script as soon as possible, hopefully with John's help. But please bear in mind that my time and resources are very limited, and my workload is huge. PI grows and grows but our resources are always the same.
It is worth doing it, and if you know and organize your data and your work well, it isn't so time consuming. It is not a fully automatic procedure like in other applications, but heck, other applications don't provide even a 10% of the accuracy and flexibility you have with our ImageCalibration, StarAlignment and ImageIntegration tools.
Offline RobF2
  • Rob
    • Rob's Astropics
« Reply #113 on: 2011 October 19 04:11:14 »
Yes Juan, I've tried a lot of different programs, and although I can by no means claim to be an expert on them, I have never managed to obtain the fantastic fidelity that PI gives - particularly the Star Alignment and Image Integration routines (probably I just don't know enough maths to fully appreciate the Image Cal module even though I use it all the time).  I always hate myself later if I do a "quick and dirty" using something else   :-[
Rob's Astropics
Offline RBA
    • DeepSkyColors
« Reply #114 on: 2011 October 19 08:59:18 »
The first part is not a problem. The second part is your choice.
« Reply #115 on: 2011 October 20 00:46:00 »
That's easy to say if you look at the PI project from the outside. But the fact is that despite we are growing, we don't manage to grow enough to make a 'jump' to a higher level in terms of business. On March we hired Javio, who is doing a great work after an initial learning period that still continues (have you noticed the new documentation and tools we have released lately?), and we are to invest a 'lot' (to our scale) of resources into new video tutorials, but again we are far from being able to make the jump.
Also take into account that we are where we are. Everything is very different in the US. Here in Spain a company like ours and a project like PI are completely inviable. The fact that PI can exist and survive is a miracle; a singularity that is only possible because I am so lucky (and so insane) that I can afford it for reasons that are beyond this discussion. With the exceptions of a few users who are supporting us since the beginning, and our collaboration with the OAUV, nobody helps us here at all; it is exactly the opposite.
So if you have some spare 200,000 euros and you are wondering what to do with them, I can give you some good ideas :)
Offline RBA
    • DeepSkyColors
« Reply #116 on: 2011 October 20 08:59:22 »
I still think "the second part is your choice". And maybe, just maybe, it's the right choice - likely it is for you. Any further discussion, I'll take it off the forum (no, I don't have €200k to invest ;) )
Offline mmirot
« Reply #117 on: 2011 October 29 20:35:32 »
Get the paddles out Juan.  Script need a jump start before it flat lines. ;)
Max
Offline David Raphael
    • Astrofactors CCD Cameras
« Reply #118 on: 2012 January 01 12:27:54 »
I found that the script fails with the current version of the Debayer module.
I hacked in a quick fix and attached in case anyone needs it.  It was failing based on the fact that it using code from the BatchDebayer script - and it hadn't been updated since that script was changed to leverage the new functionality in the debayer module.
Dave
David Raphael
