Author Topic: Question about Canon DSLR milky background removal - limited success  (Read 7482 times)
astropixel
  • Guest
What is the best way to deal with the milky background associated with some DSLR cameras in PI. I notice that with a significant non-linear stretch my images reveal uneven whiteness across the image. To a large extent I have minimized the effect with Windorized or Percentile clipping, but the residual makes it impossible to stretch and obtain brightness and colour. Background extraction tools have not helped, and I have tried various different approaches during non-linear processing with little success.
Basically, this artefact prevents getting the best out of significant data.
are you sure this is a camera artifact and not due to light pollution? i'm not sure i've ever seen uneven whiteness but i definitely get some strange gradients sometimes...
Could you post an example image. I think I dont see this problem with my Canon EOS 40D.
astropixel
  • Guest
Thanks for taking an interest in this.
I extracted the L* channel to highlight the issue. I will resist the temptation to think out loud, except to say that this translates to a very muddy background.
Offline Cleon_Wells
Have you tried not calibrating your subs to eliminate the possibility that the Master Calibration files are not causing this problem?
Cleon
astropixel
  • Guest
I'm hesitant to say that it's a calibration problem. I don't want it to be >:( The initial stretch produces a very flat image - evident in the RGB and extracted L*. But this is only achievable with Windsorized clipping on the large set - 247 lights, and Percentile clipping on smaller experimental sets - 3 lights.
Integration with Linear clipping, the problem was evident from the first stretch - I assumed to have selected the wrong clipping algorithm.
I have no reservations concerning the bias and dark frames - they are easy to acquire and process. But, I dread the thought that it may come back again to the flats that I am producing???
I wonder if this is the general background "dust" in this region of Orion. See http://de.wikipedia.org/wiki/Datei:Orion_Belt.jpg for example.
Offline Cleon_Wells
Georg may have the answer. Just what is the the total time in the 247 lights?
Do you examine the three channel list created with II after integration?
Cleon
astropixel
  • Guest
I did think of dust, but discounted it on the basis of the total exposure time - just 67 mins, made up of 10, 15, 20 and 30 second exposures - f/3.2, iso800.
The other problem was differential flexure. Exposures are unguided, but alignment was unusually good and I should have dithered the frames periodically - could this contribute to the problem? Originally the image was streaky, but I managed to process a lot of this out. Maybe it shows up with non-linear processing and more extensive stretching.
If it is dust, then this is all too funny - I've spent hours attempting to eliminate good data. :'(
astropixel
  • Guest
Here is a masked version just to illustrate the extent and nature of the problem. Is this recoverable?
Re: Question about Canon DSLR milky background removal - limited success
« Reply #10 on: 2011 February 09 08:56:14 »
check this widefield - the entire area is full of dust...
http://www.flickr.com/photos/31986095@N05/5281522077/
it does show up even in shorter exposures. and it looks... kind of milky when the signal is low...
astropixel
  • Guest
« Reply #11 on: 2011 February 09 18:20:42 »
Comparing images, I see faint evidence of dust areas, but overall I think this is an artefact - possibly the result of trying to squeeze to much out of the image. I've just about given up on this set.
Offline David Raphael
    • Astrofactors CCD Cameras
« Reply #12 on: 2011 February 09 20:35:05 »
Here is the same field - I don't think you have milkyness...I see dust ;-)
http://www.flickr.com/photos/21315110@N00/5343866972/
Don't look too closely at my picture...it is not a very good one...
David Raphael
astropixel
  • Guest
« Reply #13 on: 2011 February 10 01:57:04 »
Very nice David. Thanks everyone, I concede - dust! Stunning area - just needs more data.
This time I started out with ACDNR following the first non-linear stretch.
Given my skills, this is as much as I can get out of it - a long way to go, I understand.
Comments/feedback most appreciated.
Offline Redshift
« Reply #14 on: 2011 February 10 02:56:23 »
I think you've got the start of a good image there. I like the colour in the Flame and the Orion nebula. Stick with it and get more subs.
Regards
Dave
