Author Topic: Synthetic Green Channel  (Read 8839 times)
Offline Redshift
« on: 2011 January 21 06:17:33 »
Is it possible to make a Synthetic Green Channel from Ha and OIII date in PI, so I can make a BiColour Image?
I've been playing around with PixelMaths for a few hours but I'm not getting anywhere.
Dave
Offline Andres.Pozo
Re: Synthetic Green Channel
« Reply #1 on: 2011 January 21 09:21:06 »
I don't know where do you want to get  ;) ;) but with Pixel Math is easy to get a green channel mixing other channels. Please watch the attached screen capture: using PixelMath I got an RGB image with a green channel composed of 66% Ha and 33% O3. After this, I applied a BackgroundNeutralization, a ColorCalibration and a STF.
« Reply #2 on: 2011 January 21 09:24:18 »
I assume you want to create a TRIcolor image then, right? :) I don't see the appeal of sticking R and B values into G but I know it's commonly done. Pixelmath is the way to do it. Which formulas have you tried? More importantly, what are you trying to do? You can't -create- Green afterall. The best you can do is mathematically combine R and B which means the signal in G is essentially the same as in R and B. Anyway, what formula do you want to use? Which PM formulas have you tried?
Offline Redshift
« Reply #3 on: 2011 January 21 10:03:51 »
Andres and Sander,
Thank you for your replies. I'm trying to emulate Steve Cannistra's technique here http://www.starrywonders.com/bicolortechniquenew.html he uses Photoshop I was hoping to do it in PixInsight. Here is one of his images using the process http://www.starrywonders.com/rosettebicolor.html.
I've only tried the PixMaths process that Andres suggests using different weights for the Ha and OIII in the Synthetic Green channel.
Regards
Dave
« Reply #4 on: 2011 January 21 10:36:52 »
Hmm, that technique sounds like alchemy and I don't subscribe to that :) Hopefully someone has translated all those PS operations into what's actually going on underwater so it can be written as PM or other processes. It'll take a careful read and understanding of what the PS layers really do.
Offline Redshift
« Reply #5 on: 2011 January 21 13:07:41 »
Sander,
I like it  :) and he's turned out a good looking photograph.
Yes, what do the Screen and Multiply Layers etc do.
Dave
Offline Nigel Ball
    • Astrophotography by Nigel
« Reply #6 on: 2011 January 21 14:53:30 »
Dave
The various PS blending modes can be implemented fairly easily in PixelMath once you know the formulae
Rogelio has a guide to PS Blending Modes on his website which I found very useful and was able to implement those I needed in PixelMath
Have a look at http://blog.deepskycolors.com/archivo/2010/04/21/formulas-for-Photoshop-blending-modes.html
HTH
Nigel
PS If you have problems with PixelMath just call .......  ;)
Nigel Ball
ST-10XME, Astrodon HaLRGB
www.nigelaball.com
Offline Redshift
« Reply #7 on: 2011 February 02 00:54:00 »
Nigel,
Thank you, I've just seen your message. I don't know how I missed it.
Regards
Dave
Offline dlp
« Reply #8 on: 2011 February 19 08:56:21 »
I'm trying to use Pixel Math as per the formulae on the deep sky colors website listed above and am having a problem parsing a formula for 'soft light' :
if (blend > 1/2) R = 1 - (1-target) * (1-(blend-1/2))
if (blend <= 1/2) R = target * (blend+1/2)
Gives 'unknown function identifier'. I have my images named as 'blend' and 'target', and symbol 'R' just entered into the Symbols box.
Can anyone enlighten me please?
David
Offline oldwexi
    • Astronomy Pages G.W.
« Reply #9 on: 2011 February 19 10:01:57 »
Hi David!
When i want to use the so called "Soft Light" function from PS in PI
i paste into PixelMath this formula:
iif(Blend > 0.5, 1-(1-Target)*(1-(Blend-0.5)), Target *(Blend+0.5))
The names of the images (layers) therefore are:
Blend and Target ....
Hope this helps
Gerald
Offline dlp
« Reply #10 on: 2011 February 19 10:07:39 »
Thanks Gerald - worked a treat!
