Author Topic: Layout for interface  (Read 5120 times)
Offline David Raphael
    • Astrofactors CCD Cameras
« on: 2011 January 20 12:47:07 »
I've seen a number of ways to control the layout of the interface - which of the modules should I use as a best practices example?
Right now this looks like sh*t.  I've attached a screen shot of the current progress, and I am not happy with how random the layout is.
Maybe the answer will just be - you have to tweak it/season to taste....
But I'd really like to know if there is a little more of a baseline I can setup AND then tweak to my liking...
I hope that made some sense.
David Raphael
Re: Layout for interface
« Reply #1 on: 2011 January 20 13:45:16 »
The best way to go ussually is to work over something it is working ;)
To keep things better organized I would use GroupBoxes. Also the Sizers let you organizaze things.
If you use Labels, make sure to use the SetFixedWidth( int ) function to force them all to have the same size. Define that at the start, as a variable as here: int labelWidth1 = fnt.Width( String( "Mechanical stimulus application frame:" ) + 'T' );
« Reply #2 on: 2011 January 20 14:07:53 »
That was a huge help.  I have more to fix, but that really fixed the label alignment that was driving me nuts...
David Raphael
« Reply #3 on: 2011 January 20 19:15:04 »
Ok - I'm stuck on this one now - I can't get these buttons to align to the top of the VerticalSizer...
David Raphael
« Reply #4 on: 2011 January 20 19:19:17 »
And of course...I figure it out 1 minute after posting...
CameraListButtons_Sizer.AddStretch();
seems to fix the problem.
David Raphael
« Reply #5 on: 2011 January 21 03:36:14 »
Very nice David :)
You need some more horizontal spacing between the vertical sizers but it's looking really nice. Good!  8)
