Author Topic: Maximization Limit resets  (Read 4884 times)
Offline Enzo De Bernardini
  • Resistance is futile.
    • Astronomí­a Sur
« on: 2011 January 13 17:44:14 »
When I maximize, normalize, iconize or shade a image window, the maximization limit resets itself, and returns to default width. Starts happening after moving some toolbars. Win XP 32.
Greetings,
Enzo.
Offline FunTomas
    • Astrofoto.sk
Re: Maximization Limit resets
« Reply #1 on: 2011 September 13 21:53:20 »
When I set maximization limit to some position, it reset to default position after restarting PixInsight. I can't find method how to set this thin line to my desired position. Any hint? Thanks.
    • Astronomí­a Sur
« Reply #2 on: 2011 September 14 07:37:35 »
Here this detail remains: when I maximize the window, the limit moves. Not a big problem, but curious.
Enzo.
Offline jerryyyyy
    • Astrobin Images
« Reply #3 on: 2015 November 01 20:38:02 »
Has this been resolved.  I just posted this to the main forum.  Still there.
Takahashi 180ED
Astrophysics Mach1
SBIG STT-8300M and Nikon D800
« Reply #4 on: 2015 November 02 06:01:15 »
Which version of PixInsight are you using?
Offline jerryyyyy
    • Astrobin Images
« Reply #5 on: 2015 November 02 06:46:24 »
Ripley 1.08.04.1170 x64.
I can delete the post off the regular forum if this is the correct procedure.
Takahashi 180ED
Astrophysics Mach1
« Reply #6 on: 2015 November 02 14:06:54 »
Hi jerryyyyy,
These are the latest versions:
Windows — 01.08.04.1185 Ripley
Linux — 01.08.04.1187 Ripley
FreeBSD — 01.08.04.1123 Ripley
OS X — 01.08.04.1123 Ripley
I checked on Linux and it is working fine.
Saludos, Alejandro.
Offline jerryyyyy
    • Astrobin Images
« Reply #7 on: 2015 November 03 20:42:30 »
I removed the old version and reinstalled twice.  I get the program running but it displays the main window in too large a size.  I cannot seem to control the screen resolution within the application.
Takahashi 180ED
Astrophysics Mach1
Offline jerryyyyy
    • Astrobin Images
« Reply #8 on: 2015 November 27 13:58:48 »
I am having the problem of the maximization reset again after installing the new build:
PixInsight Core 01.08.04.1193 Ripley (x64)
Hope this is the new one.  Just downloaded.
Reset limit will not stay in place.
Takahashi 180ED
Astrophysics Mach1
Offline jerryyyyy
    • Astrobin Images
« Reply #9 on: 2015 December 02 07:04:11 »
Bump.  This still happends intermittantly.  Are there any settings involved that can be purged or reset?
Takahashi 180ED
Astrophysics Mach1
