Hi all,
I've recently acquired a Canon 1000D and modded it with the Baader filter. I have taken a pile of 3 min subs near the Heart and Soul Nebula in full RGB through a Pentax 67 lens. However, whatever I do, I find that the smallest stars are always green....see zoomed in jepg of a central region below:
In the above image you can see that ALL of the smaller stars are green.
This is the result of 20 subs stacked in DSS....but I get exactly the same result with a single sub...just noisier.
I start with the Autosave file (32bit TIF), then use PixelMath with the following expression to neutralise things...
R $T[0]/med($T[0])
G $T[1]/med($T[1])
B $T[2]/med($T[2])
By the way, the starting medians for the RGB are 0.269, 0.104 and 0.112....so the red is quite a bit higher than the other two.
So this puts the three histogram peaks on top of each other.
At this point I can just apply STF (three channels locked together) and I see the small green stars....OR I can go through a full BackgroundNeutralisation and ColorCalibration process...and I still see the small green stars.
I have tried varying just about every setting in DSS...always get the small green stars....and anyway, I get the same result if I look at just a single RAW sub....which sort of rules out DSS.
Any ideas as to what I am doing wrong?
Cheers
Simon
