Author Topic: Image Registration of DSLR data  (Read 8030 times)
Offline dsnay
« on: 2011 January 05 04:44:41 »
Is there some change I could make to the settings in the Image Registration window which would speed up the process of registering the monstrous files produced by DSLR's without negative impact on the results? I don't understand the various fields in there well enough to make an educated guess.
Dave
Offline sjbrown
Re: Image Registration of DSLR data
« Reply #1 on: 2011 January 05 06:39:45 »
Hi Dave,
You could reduce the Maximum stars setting under the Star Matching bar from the default (Auto) of 2000.
When I run a subset from a given night I reduce it as low as 200 stars with excellent results and a huge
cut in the processing time. For production runs of multiple subsets I leave the default setting just to ensure
quality of the alignment.
Hope this helps,
John
Offline dsnay
« Reply #2 on: 2011 January 07 09:22:49 »
Thanks John.
Offline dsnay
« Reply #3 on: 2011 January 11 04:46:17 »
Hi Dave,
Hope this helps,
John
John,
When I expand that bar, the only field with a value of 2000 is the Ransac Iterations field. The Maximum Stars field is set to "Auto". Should I be setting that field to 200?
thanks,
Dave
Offline sjbrown
« Reply #4 on: 2011 January 11 07:53:26 »
Yes, the "auto" setting usually equates to  a value of 2000 stars for my images (12 MP on a Canon 450D). The value of
200 is an arbitrary value but it still produces very good results.
John
