Author Topic: General question about sharpening / ATWT  (Read 5142 times)
Offline David Raphael
    • Astrofactors CCD Cameras
« on: 2011 January 04 08:51:44 »
I've read many discussions about how deconv should be used - and one of the points that has been emphasized is that it is not intended to be used as a sharpening tool...
I've also read that ATWT can be used as a sharpening tool...
Maybe I'm missing something big here, but I don't understand how one would use ATWT as a sharpening tool.  Can anyone explain this to me?
Dave
David Raphael
Re: General question about sharpening / ATWT
« Reply #1 on: 2011 January 10 10:47:18 »
No one?
David Raphael
Offline Andres.Pozo
« Reply #2 on: 2011 January 11 02:33:43 »
You only have to increase the weight of the smaller layers. This is a trivial example without masks:
Offline avastro
« Reply #3 on: 2011 January 11 02:34:54 »
Hi Dave,
Let me try to explain you how I use ATWT for sharpening.
Depending a what part of the image I'm interested in sharpening, I build a mask to protect the other part.
Usually I build a star mask and invert it if needed.
I select in ATWT the number of layers adapted at my image usually 5 or more, then I use a positive bias to the layers corresponding to the part of the image I'm looking for sharpening. Usually between 0.1 and 0.05 in layer 2 and layer 1 sharpen quit well fine details.
If your image is noisy it's better to avoid increasing the bias in layer 1, just remove it.
I hope this quick explanation will help you.
Cheers
Antoine
Antoine
Lentin Observatory
« Reply #4 on: 2011 January 11 07:55:16 »
Thanks gents!
Do you normally do this pre or post stretch?
David Raphael
Offline avastro
« Reply #5 on: 2011 January 11 13:52:57 »
Hi Dave,
I generally do that at the end of my process, when I try to find the last small improvements.
Cheers
Antoine
Antoine
Lentin Observatory
