Author Topic: StarHaloReducer script  (Read 4503 times)
Offline Nigel Ball
    • Astrophotography by Nigel
« on: 2010 December 28 02:48:20 »
I've been using the StarHaloReducer script to get rid of some rather large halos in a Ha image of IC443.
Here's my problem. No matter how much I fine tune the settings I always get a dark line around the edge of where the halo was
Does anybody else get this?
Nigel Ball
ST-10XME, Astrodon HaLRGB
www.nigelaball.com
Offline Silvercup
Re: StarHaloReducer script
« Reply #1 on: 2010 December 30 05:45:09 »
Hi Nigel, sorry for the late answer but I have a lot of work and developing and ASCOM driver.
When you got dark halos you are darken too much the background's Halo. StarHaloReducer is more efective with a iterative aplication. I.e. it's better appliying 3 times with smal amounts than 1 with more amount.
Althought you don't notice de difference between images, when you run script 3 times you will see the difference from original.
If you upload a image with the halo, I can try to find the settings.
Best, Silvercup
